I really wish one of you very smart people could record yourself completing this process to show us idiots how to make this test circuit
Hi Bill, can you show me how you did it? Thanks.
Did what?
The GWM wiring to turn on an APIM. Please, thank you.
I used the GWM to upgrade calibrations on Modules not to turn them on.
Thank you man. Just wondering the wiring? Do u connect the HSCANs from GWM to the APIM and connect power to GWM and APIM and you can connect OBD 2 on the back of the GWM? Just want to confirm if Iām right.
Yes, Power to the GWM and the module I am programming. Some require multiple grounds. You may already know but modules are always powered and the Can signal is what turns them on. You want them turned off for calibration updates.
As far as the OBD I use a previous saved configuration to get it started. Only exception is if you are doing a BCM or have one connected. Than it will use that for the look up on a fresh profile.
Happen to sell these premade?
