Sync 3 error in maps extracting. I did mistake to add maps in non nav apim what should i do now? any solution?
Sync 3 screen stuck during extracting Maps data and showing error and after that only showing please insert usb stick. How to get back to normal screen. Is anyone go through this? Thanks in advance.
You could make another USB without maps and see if it will work. You only want 1 file, the Sync app file, like 3.4.23188, in the reformat file and the Sync app file in the SyncMyRide folder. You may have used up all of the storage, but there is a chance.
Thank you @F150Chief i tried it with only one file and now i am back to the normal screen and can upgrade to upper version. Thanks //@devendramehra
