Hello is there anything I can do to disable 360 cameras and have a full screen camera when in reverse? This is sync 4 retrofited in 3
You just tap the camera button on top and it will cycle through the views.
Non of buttons work on top screen can’t change views
The button on the top right connects to the IPMB, when you push it that changes the camera view to the APIM. Installing Sync 4 does not change how this functions. There is nothing you can change in the APIM AB that will affect the signal it receives. You can change the AB in the IPMB that will affect the picture it is sending.
Did you change the whole dash? This is not what a 2017 F250 dash looks like.
Thank You so much that will explain that I do got code in ipmb U0253:87-0B any idea what I can change in that module ? No I didn’t change the dash is just a custom bezel to fit 17+
Here are the IPMB AB settings.
IPMB (2015-2019) Database - CyanLabs
Maybe try changing 7B1-01-01: x*xx-xxxx-xxxx to 1 camera and see what happens.
Yeah I tried all of those settings from 1-9 and a to f but but non of them was able to control cameras from within top screen, some of those settings was able to set backup camera to full screen but didn’t
