I notice (Forscan) that you can change the presets from 6 to 10 in the ACM. Do I need certain p/n ACM? also will this work on the 8" screen.
On the APIM there is a setting for mixed presets again do I need a certain p/n APIM?
Vehicle Model: F-150
Vehicle Year: 2018
This will not work with your vehicle unless you were to upgrade the ACM to a later unit that supports the extended mixed mode presets. A MY2020 ACM would be needed. Make sure the wiring connectors match, you may need to add a pair of wires from the ACM to the APIM directly, so you will need to obtain the proper connector pins for both sides.
There are a few threads here that deal with this subject and adding SiriusXM.
Thanks.
I have SiriusXM, but my presets are only 6 would like to have the 10…
This topic was automatically closed 5 days after the last reply. New replies are no longer allowed.
