Sync3 to sync 4
I upgraded the dashboard from 2018 to a 2021 with sync4 and 12” screen and have quite few lights on on dashboard also can get foracan to read my apim module.
Upgraded acm,AC , and apim module. Do I need anything else
Install Type: Unknown
Old SYNC Version: 23045
New SYNC Version: 23045
I have some lights on on dashboard forscan no communication with apim module
Syn3 Updater Version: Forscan
N/a
You will need to use a profile from a Sync 4 equipped vehicle, like an F-150, to see the Sync 4 APIM in your vehicle. Depending on the extent of the swapped modules, you might have to use 2 profiles for your vehicle now. You could contact FORScan support, providing you have a paid license, to see if they can make a custom profile for your vehicle.
Thank you for your response really appreciate your help. I found out my APIM module that was sent to infotainment to be upgraded to sync 4 was sent back not functional. do you recommend buying a new one or do you provide apim module services. I also wanted to see if you had a digram of how ac connects to old wiring .
