Sync3 won't turn on
I recently bought a 2018 Ford Fiesta SEL 1.6 Brazilian model with Sync3.
The problem I’m experiencing is that Sync3 randomly turns on. Normally, it never turns on, but suddenly, for no apparent reason, it powers up.
I believe it’s a bad APIM, but I’d like to be sure about that. I’ve already tried removing the fuse, but that didn’t work.
I did a hard reset once when it turned on, but it didn’t help either.
Could you guide me on whether there’s any way to repair it?
If not, can you help me with the details for replacing it with a functioning one?
Thanks!
SYNC Region: ANZ
Old SYNC Version: 3.017276
New SYNC Version: 3.017276
Hello.
That in fact seems to be hardware related. If it’s a bad APIM, there’s nothing else to do but replacing it.
Have you completely ruled out any possible electrical or wiring issue?.
The thing is, it you can’t turn it on, then you can’t even try upgrading it.
Do you have Forscan and an adapter?.
Yes, I’ve already ruled out any possibility of it being an electrical issue.
I’m looking to replace the APIM, but honestly, I’m afraid it might happen again.
I’m sending photos of the Sync3 version as well as the APIM model.
That’s the assembly PN, not the APIM’s.
It’s odd that it starts with J and has a date from 2017, but maybe assemblies have a different nomenclature…
I don’t have Forscan or an adapter. How can I check the APIM number?
Do you know which adapter I should buy?
This one is the APIM number?
JA6T-14G370-ABB
As I said before, it’s not.
Do you have an example code? To look something similar?
APIMs have 14G371 as part of the part number…
You can get a J or K series, do not get an L one since it’s MY20. You can check our db for reference → SYNC 3 APIM Hardware Database - CyanLabs , because there are some J series that are MY20 since they are replacement units. Always check the sticker on the back and on the db, I do not recommend getting MY20 hardware. You can’t reformat them with Syn3Updater.
The storage will depend on the vehicle having nav or not.
I found these codes attached to the APIM; does any of them work?
