Sync4 ANZ maps
Hey guys
Not sure if ok to post this or in right spot.
Looking for info on bringing the anz maps onto a USA built f250.
I have the tcu working with Ford pass by putting in an aus built f150 tcu unit. I also still have foe aus built f150 with the ANZ maps on it somewhere in the apim.
Is it possible to somehow extract the maps using fdrs from the aus built f150 and build into the apim of the f250?
Or are there any regional settings that need to be updated now that the tcu is working?
Thanks in advance
You can’t extract the files from an APIM using FDRS or ForScan.
Using anything else?
Might be able to use the FMods map replacement tool to remove the existing maps and put the correct ones in.
You would also more than likely have to change the region and map type in the APIM as well as changing the firmware.
NA maps are Telnav, ROW is NNG.
