Syns 3.4 my2020 conversion US to EU
What do I need to do to convert?
I need to do JB and then I can use cyanlabs sync updater to upload new maps?
will JB remove old maps from the US?
Is there a list of which file is responsible for which country/map? I’m limited by 32gb apim so I’d like to choose only the ones I need
There is a FMods map remover that can be used to pull out the maps.
Basically use ForScan to flip the but so that the APIM becomes “non-NAV”, run the remover and then use the cut down map installer…
Afterwards flip the bit back and change the APIM region from US to the EU.
