Hi,
I brought Explorer 2021 3.3 hybrid to Europe. To be able to use the FordPass function, I replaced the TCU with the European KT1T-14G087-ES. I entered all the settings and activated the vehicle from the application. Now everything works properly, the TCU module is logged into the network, I can see the fuel level and I can open / close and start the engine. The only problem is locating the car. It still tells me where I last logged into the US network. in block 754-10-01 I entered the location of PL
What did I set wrong? is there a coding error somewhere?
You need to set the region and country codes.
I have the region set to Poland in line 754-10-01 504C. I also changed the lines to 754-01-01 xx38 xxxx xxxx with no effect. I tried doing a reset, but that didn’t help.
You will need to re-activate the unit after setting the region.
I have my region and country set correctly. Resetting didn’t help. But it looks like I have something set wrong. According to the application, the last time it synchronized positions was September 17, 2021.
1FM5K8FW6MNA11602_TCU_B338_PL.abt (1,6 KB)
;Block 1
754G1G1B33800000048
754G1G2005E
;Block 2
754G2G11B2099
;Block 3
754G3G17D7D7D7D7DD0
754G3G27D7D7C7C7CCE
754G3G37C7C7C7C7CCD
754G3G47C7C7C7C7CCE
754G3G57C7D7D7C7CD1
754G3G600787D7D7D53
754G3G77D7D7D7D7DD6
754G3G87D7C7D7C7CD4
754G3G97C7C7C7C7CD3
754G3GA7C7C1E84
;Block 4
754G4G17C7C7C7C7CCC
754G4G27C7C7C7C7CCD
754G4G37C7C7C7C7CCE
754G4G47C7C7C7C7CCF
754G4G57C7C7C7C7CD0
754G4G67C7C7C7C7CD1
754G4G77C7C7C7C7CD2
754G4G87CE3
;Block 5
754G5G17C7C7C7C7CCD
754G5G27C7C7C7C7CCE
754G5G37E7C7C7C7CD1
754G5G47C7C7C7C7CD0
754G5G57C7C7C7E7ED5
754G5G67C7C7CDA
;Block 6
754G6G17D7D7D7C0358
754G6G27D00000000E0
;Block 7
754G7G103C4A014F1CF
754G7G2681E0F0A181B
754G7G34B00640A0220
754G7G43C1E1F425879
754G7G50F1B4CFF704C
754G7G6000068
;Block 8
754G8G105060505057E
754G8G202020506067A
754G8G3050505057A
;Block 9
754G9G16163662E6926
754G9G26E7465726E8D
754G9G365742E756B4E
754G9G42E6F747400ED
754G9G5000000000069
754G9G600000000006A
754G9G700000000006B
754G9G800000000006C
;Block 10
754GAG1504C08
;Block 11
754GBG130303030305D
754GBG230303030305E
754GBG330303030305F
754GBG4303030303060
754GBG5303030303061
754GBG6303030303062
754GBG7303030303063
754GBG8303030303064
;Block 12
754GCG130303030305E
754GCG230303030305F
754GCG3303030303060
754GCG4303030303061
754GCG5303030303062
754GCG6303030303063
754GCG7303030303064
754GCG8303030303065
;Block 13
754GDG17D7D7D7D3C9F
754GDG20ADE1E012CA3
;Block 14
754GFG1000000780FF8
754GFG20277EB
;Block 15
754H0G103E85D
;Block 16
754H1G10A0000A84065
754H1G2A25807804035
754H1G3F03C0F0505BA
754H1G40379
Do you have the original TCU asbuilt from the vehicle?
I got a brand new TCU from a Ford dealer
The asbuilt from the NA TCU you removed…
it is from original US TCU
1FM5K8FW6MNA11602_TCU_Explorer oryg.abt (1,9 KB)
Your VIN lookup on Ford ETIS shows that this vehicle is:
1FM5K8FW6MNA11602
Explorer 2020-, 1.6L SOHC EFI NA I4 GAS*MAZDA, Carbonized Gray/Asher Gray…
But searching the VIN and finding the vehicle for sale indicates it is a 3.3L V6 FI DOHC 24V NF4.
I can see that the firmware from the original TCU is apparently newer than what you have now with the EU TCU and is different. The asbuilt lines do not line up, and this is due to the TCU firmware versions.
This is the original TCU:
F10A>LB5T-14G144-SH
F110>DSLB5T-14G087-AJ
F111>LB5T-14G145-SA
F113>LB5T-14G087-SH
F16B>14G643
F188>LB5T-14G139-SH
F18C>UC1U02TX
The LB5T TCU has additional functions for the EV vehicles especially. The KT1T firmware is older, but I think the asbuilt block that matters might be the same.
Look at 754-07-06
On your EU TCU, the value is 0000 68.
The value on the original NA TCU is 1112 8B.
In this line, it sets the GPS Source parameter. (I am not sure which byte this is, but the parameter options are:
GNSS Source: 0=TCU GNSS, 1=Other.
I don’t know if this is the answer, but you could try it. You will likely need to reset the TCU after making the change.
I have seen other instances of this, coincidently with Explorer vehicles. I do not know what causes this, other than maybe the vehicle is still captured by the other TCU registration with Ford. I would suggest upgrading the firmware in the new EU TCU. I do not know if this will fix the issue.
Thanks, I’ll check and let you know.
