Transit Connect 2015 XLT Wagon No APIM
Hello,
Thanks for the opportunity to participate in this community. I’m trying to figure out whether I can add an APIM to my 2015 TC XLT Wagon which I don’t believe has one. It has the 4-inch display with no phone connectivity. Would be great if I can get a larger screen while I’m at it. It has manual HVAC controls currently.
I downloaded the asbuilt from Motorcraft based on my vin, below is the html version.
Really just trying to figure out what my options are and a shopping list for the junk yard. Any guidance is appreciated.
PCM Modules
PCM 1 FFFF FFFF FF0C
PCM 2 FFFF FFFF FF0D
PCM 3 FFFF 0FFF 2F4E
PCM 4 FFFF 1F33 FF63
PCM 5 FFFF FFFF FF10
PCM 6 FFFF FFFF FF11
PCM 7 FFFF FFFF FF12
PCM 8 FFFF FFFF FF13
PCM 9 FFFF FFFF FF14
BCE Modules
Module Address Instructions
7A5-01-01  	0308  	600E  	0027
7A5-01-02  	0000  	AF
7A5-02-01  	0005  	5553  	5C
7A5-03-01  	00B0
7B1-01-01  	0072  	0109  	36
7B1-02-01  	0102  	0103  	01C3
7B1-02-02  	0102  	BF
7B1-03-01  	50C8  	D4
720-01-01  	0000  	0142  	6C
720-02-01  	3801  	0509  	0E7F
720-02-02  	1217  	1C21  	26B7
720-02-03  	2C32  	3941  	4A4E
720-02-04  	5562  	7285  	9D78
720-02-05  	BBE1  	0000  	00CA
720-02-06  	002F
720-03-01  	0000  	000C  	37
720-09-01  	0000  	00C0  	F1
720-19-01  	0105  	090E  	1270
720-19-02  	171C  	2126  	2CE8
720-19-03  	3239  	414A  	558E
720-19-04  	6272  	859D  	BBF5
720-19-05  	E126
720-23-01  	FCFF  	F3FE  	37
726-01-01  	5F14  	0324  	723B
726-01-02  	0080  	80B4  	09ED
726-01-03  	413C  	1200  	00C0
726-01-04  	0161  	0202  	3CD4
726-01-05  	090D  	0000  	0049
726-01-06  	1041  	0100  	0086
726-01-07  	0000  	7D00  	28DA
726-01-08  	0000  	0000  	0036
726-01-09  	0000  	0000  	0037
726-01-10  	0000  	0000  	003E
726-02-01  	0004  	292C  	89
726-03-01  	0101  	33
726-04-01  	0100  	33
726-05-01  	0033
727-01-01  	E800  	2401  	003D
727-01-02  	0536
727-02-01  	3465
727-03-01  	1547
727-04-01  	0001  	0255  	53DE
737-01-01  	4E4D  	3041  	4591
737-01-02  	3846  	3738  	4674
737-01-03  	3132  	3030  	353A
737-01-04  	3730  	AA
737-02-01  	4768  	CE30  	10FE
737-02-02  	0C77  	00C5
737-03-01  	0F51
737-04-01  	0043
737-05-01  	C331  	38
737-06-01  	0D55  	A7
760-01-01  	4E4D  	3041  	45BA
760-01-02  	3846  	3738  	469D
760-01-03  	3132  	3030  	3563
760-01-04  	3730  	D3
End of information
You can retrofit Ford Sync 3 into a 2015 Transit Connect using a wiring kit from several vendors. Or, you can do the wiring yourself but it’s not a small task. As far as the Sync 3 functionality, not everything will be supported, especially in later versions for Sync 3.4, compatibility wise anyways. Overall the swap will work fine.
I suggest you look into articles on the Transit forums specifically for your vehicle. There would be specific information about the addition or swap of Sync 3 into a Transit Connect and the required programming. Although you will need to acquire the wiring from someone to do this, you can purchase the other parts such as the APIM, ACM, Etc., likely significantly cheaper than from the kit folks.
Forums - Ford Transit Connect Forum
Ford Transit Connect General Discussion | Ford Transit USA Forum
Transit Connect Forum - Blue Oval Forums
Ford Transit Forum • View forum - Transit Connect
Search results for ‘transit connect Sync 3 #ford’ - CyanLabs Official Community
Based on what I’ve read so far it seems that all 2014-2018 TC’s in NA use the IPC as the gateway for CAN. I guess that means getting parts from 2019 or newer might mean that I’d need to also add a dedicated gateway module, which might not be feasible.
I see a lot of different wiring harnesses on ebay and amazon but nothing really specific to Transit Connect. Since it is built on the same C1/B platform as Focus, C‑Max, and Fiesta, I guess I should be looking for harnesses compatible with those vehicles (that are CGEA 1.2). My last question is whether the fact that my vehicle has an OEM rear camera makes a difference and if I should use this as an opportunity to upgrade the rear camera since it looks like crap.
This is the CGEA 1.2 network you have. It will only use the IPC for the ICAN network. The MS and HS networks come from the BCM. There is no gateway module and you cannot add one. The module calibrations would not talk correctly if you plug one in.
You are partially correct on parts from a CGEA 1.3 network working on a CGEA 1.2 network. Some modules will without problem but MOST will not. The small amount that do work allow the AB to be changed to 1.3 and that is why. When I say small amount I mean like 2 or 3 modules.
Found a 2014 TC with 6.5” screen. Got the APIM, Screen, FCIM, Bezel, Bracket, Center Dash Cover, CD Player and Instrument Panel.
Was unable to get the steering wheel or clockspring due to being out of town without all my tools. Will any steering wheel from a Sync 3 Focus/ Escape/ C-Max/ Fiesta/ Fusion work or do I need to find another 2014-2017 TC with right hand steering wheel buttons?
Besides steering wheel and maybe clockspring I still need the USB 3.0 cable and hub that goes in front of cup holders next to E-Brake. I think I can buy that new for reasonable price though.
Anything else I need besides harness? I’ve looked around on Transit Connect Forums about buying or making one. It seems like getting a cheap one with all the connectors and rewiring it if necessary is the best compromise between expense and effort.
The only other thing I can think of is a GPS antenna but I’m not planning to use built in navigation and that’s the only thing that it’s needed for to my knowledge.
