Hi Team,
I have an issue where I have downloaded using Syn3 updater
but the update doesnt start when I put the USB in the port
Hi Team,
What is your SYNC Region? ANZ
What is your current SYNC Version? 2.3.17109
Do you have Navigation? Yes
Do you have a error message, if so what is it? No error message
Branch: Release
Version: 2.3.17109
Region: ANZ
Mode: reformat FORCED
Model: USB3.0 FLASH DRIVE USB Device 29GB
VOICE=5U5T-14G391-DN_1615429668000.TAR.GZ
APPS=5U5T-14G381-ER_1615427592000.TAR.GZ
; CyanLabs Syn3Updater 2.x - reformat Mode - Sync 3.4.21020 ANZ
FILES (7)
5U5T-14G391-DN_1615429668000.TAR.GZ (1GB)
5U5T-14G381-ER_1615427592000.TAR.GZ (847.1MB)
4U5T-14G422-DG_1615429764000.TAR.GZ (1.5GB)
4U5T-14G421-DAF_1615429515000.TAR.GZ (4.6GB)
4U5T-14G424-DAF_1616778205000.TAR.GZ (1.6KB)
[7/05/2021 7:46:54 pm] Selected Region: ANZ - Release: Sync 3.4.21020 - Map Version: 2.20 (2020) - ANZ, SA and TW
[7/05/2021 7:46:54 pm] Install Mode: reformat
[7/05/2021 7:46:54 pm] Checking Existing File: 1u5t-14g386-cb.tar.gz
[7/05/2021 7:46:54 pm] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[7/05/2021 7:46:54 pm] Checking Existing File: 5U5T-14G391-DN_1615429668000.TAR.GZ
[7/05/2021 7:46:58 pm] Validated: 5U5T-14G391-DN_1615429668000.TAR.GZ (Skipping Download)
[7/05/2021 7:46:58 pm] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[7/05/2021 7:47:02 pm] Validated: 5U5T-14G381-ER_1615427592000.TAR.GZ (Skipping Download)
[7/05/2021 7:47:02 pm] Checking Existing File: 4U5T-14G423-DC_1615429585000.TAR.GZ
[7/05/2021 7:47:05 pm] Validated: 4U5T-14G423-DC_1615429585000.TAR.GZ (Skipping Download)
[7/05/2021 7:47:05 pm] Checking Existing File: 4U5T-14G422-DG_1615429764000.TAR.GZ
[7/05/2021 7:47:11 pm] Validated: 4U5T-14G422-DG_1615429764000.TAR.GZ (Skipping Download)
[7/05/2021 7:47:11 pm] Checking Existing File: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[7/05/2021 7:47:30 pm] Validated: 4U5T-14G421-DAF_1615429515000.TAR.GZ (Skipping Download)
[7/05/2021 7:47:30 pm] Checking Existing File: 4U5T-14G424-DAF_1616778205000.TAR.GZ
[7/05/2021 7:47:30 pm] Validated: 4U5T-14G424-DAF_1616778205000.TAR.GZ (Skipping Download)
[7/05/2021 7:47:30 pm] Preparing USB drive
[7/05/2021 7:47:30 pm] Checking Existing File: 1u5t-14g386-cb.tar.gz
[7/05/2021 7:47:30 pm] 1u5t-14g386-cb.tar.gz exists and validated successfully, skipping copy
[7/05/2021 7:47:30 pm] Checking Existing File: 5U5T-14G391-DN_1615429668000.TAR.GZ
[7/05/2021 7:47:41 pm] 5U5T-14G391-DN_1615429668000.TAR.GZ exists and validated successfully, skipping copy
[7/05/2021 7:47:41 pm] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[7/05/2021 7:47:50 pm] 5U5T-14G381-ER_1615427592000.TAR.GZ exists and validated successfully, skipping copy
[7/05/2021 7:47:50 pm] Checking Existing File: 4U5T-14G423-DC_1615429585000.TAR.GZ
[7/05/2021 7:47:59 pm] 4U5T-14G423-DC_1615429585000.TAR.GZ exists and validated successfully, skipping copy
[7/05/2021 7:47:59 pm] Checking Existing File: 4U5T-14G422-DG_1615429764000.TAR.GZ
[7/05/2021 7:48:15 pm] 4U5T-14G422-DG_1615429764000.TAR.GZ exists and validated successfully, skipping copy
[7/05/2021 7:48:15 pm] Checking Existing File: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[7/05/2021 7:49:07 pm] 4U5T-14G421-DAF_1615429515000.TAR.GZ exists and validated successfully, skipping copy
[7/05/2021 7:49:07 pm] Checking Existing File: 4U5T-14G424-DAF_1616778205000.TAR.GZ
[7/05/2021 7:49:07 pm] 4U5T-14G424-DAF_1616778205000.TAR.GZ exists and validated successfully, skipping copy
[7/05/2021 7:49:07 pm] Generating reformat.lst
[7/05/2021 7:49:07 pm] Generating autoinstall.lst
[7/05/2021 7:49:07 pm] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
but the update doesn’t start when I put the USB in the port in the car
You probably have another USB device plugged in to your car, remove it.
no other usb plugged in
Your USB is likely a cheap usb
Most branded quality USB drives will show the manufacturer, please try another USB
Second to what was already said, I would also like to point out that you should leave the install method as “auto detect” rather than forcing a reformat. While this should work as you have it now, just for future reference to avoid user error.
i think sometimes my log reports it wrong also, so i didn’t point that part out for that reason
Hi Team,
Thanks for your help with this.
I used a brand new Apacer USB I thought it was a decent brand?
Obviously didn’t work with the 32gb only had a 16gb usb around was Apacer aswell but the update worked on it so I’m not complaining maybe the other was a bad egg from factory.
Or maybe as it was a really old version of sync couldn’t handle a 32gb drive.
Yeah it was set on auto detect
But awesome support thanks again guys all working.
