See the PM I sent from the other thread…
Hi Fido,
just follow the instructions on:
Hello, I need a calibration file 1u5t-14g375-aa.Thank you
There are downloads there…
Thank you very much
Dear all
I have plan to update firmware APIM, current Sync 3.4 20282, ROW region.
Before update new Calibration, i need Calibration GB5T-14G375-GA.vbf. Can someone give me the link to download (backup in fail update).
Thanks.
What would be the correct upgrade for me ? I have original UCDS, so Access to download files.
Ucds Update wizard shows no Update available, and forscan show the attached.
Which files and order should I use if using ucds vbf loader ?
Downloaded the FORScan suggested files/calibrations with UCDS and put them in FORScan calibration folder. It automatically found them and sbl test and programming went well.
Calm screen and radio logos also works now - success
Hi… I try with forscan to enable seat heat icon… but i disable it again. Now if i use navi or other then home screen i can see a seat heat icon beside the clock. if i turn off the seat then is also go away. What have i done and how do i get it to go away ?
Where do i download the apim files to radio stations icon for dab
If you have heated seats, then this behavior is normal. If you do not, then you can go to 7D0-01-01 xxxx xxxx xXxx and make the appropriate setting.
Rear Climate Controls, Heated Steering Wheel (HSW), Heated/Cooled Seats HMI
0=Rear Climate Not Available, HSW Not Available, Heated/Cooled Seats Not Present
1=Rear Climate Not Available, HSW Not Available, Cooled Seats Present
2=Rear Climate Not Available, HSW Not Available, Heated/Cooled Seats Present
3=Rear Climate Not Available, HSW Not Available, Heated Seats Present
4=Rear Climate Not Available, HSW Available, Heated/Cooled Seats Not Present
5=Rear Climate Not Available, HSW Available, Cooled Seats Present
6=Rear Climate Not Available, HSW Available, Heated/Cooled Seats Present
7=Rear Climate Not Available, HSW Available, Heated Seats Present
8=Rear Climate Available, HSW Not Available, Heated/Cooled Seats Not Present
9=Rear Climate Available, HSW Not Available, Cooled Seats Present
A=Rear Climate Available, HSW Not Available, Heated/Cooled Seats Present
B=Rear Climate Available, HSW Not Available, Heated Seats Present
C=Rear Climate Available, HSW Available, Heated/Cooled Seats Not Present
D=Rear Climate Available, HSW Available, Cooled Seats Present
E=Rear Climate Available, HSW Available, Heated/Cooled Seats Present
F=Rear Climate Available, HSW Available, Heated Seats Present
http://ivsubinaries.azureedge.net/swparts/1U5T-14G658-AF_1598633324000.TAR.GZ
These files can be found in the IVSU Database on this site.
https://cyanlabs.net/ford-apim-ivsu-db/
i have heated seat but with fysik button. its a fiesta mk8 vignale
Change it to ‘0’…
hi did you fixed your issue.
i need to get radio logos and calm screen
Where must 0 be in the forscan ?
i have heated seat, but with fysik button. i try to turn on the version i can control on the sync3 screen, and turn it off again. but now every time the heted seat are turn on there is coming a icon on the screen by the side of the clock a heted seat icon. that was there not before as orignal
Its is only in the front seat i have heated
If the icon is only there when the heated seat is on, then it is status that it is on. Did you make the adjustment in Forscan and do a master reset?
