I decided to update my FCIM and it looks like it didn’t want to take. After it erased the module, it loaded 1 and 2 but got stuck on 3 and then failed. I tried going to another version and it also failed on 3. With that said my radio controls and HVAC stopped working (steering wheel control works). I went to update this as I’ve had an error on my IPC which happens frequently where my Hill Descent, Service Advancetrak, Pre-collision Assist Not Available. Ford has updated the TCM and upgraded the harness on the steering sensor and it keeps coming up (I do not have a lift).
I removed the battery cable to try and reset it (as well as held the radio power/seek forward for 8 seconds) and it wouldn’t turn on.
I realize that you have an OBDLink MX+, Bluetooth Adapter. This is not recommended for FIRMWARE updates, as the bluetooth will time out. Make sure that you set all of your power saving settings on your computer to OFF, as this will help. Bluetooth will have issues with maintaining the connection and speed. If you can return it and get the EX version, this would work much better. (I did the same thing.)
EDIT:
I replied to your post above with the thought that the APIM was the issue, not the FCIM. The FCIM should be recoverable thru FORScan using the original calibration files. Once you program those, you will need to load your entire asbuilt for the FCIM and reset the FCIM thru FORScan.
Your quickest approach would be to ebay a replacement fcim in honesty. It is pretty essential for operation of your vehicle. This module is highly unlikely to cause the issues you mention.
It’s far more likely to be (in order of likelihood):
Low battery voltage/old battery. - replace it.
Loose connection to ipc
Loose connection to tcu
Wiring fault on loom
Other module fault
First. I can’t seem to find the latest version of Forscan (2.4.3?) anywhere. Would anyone be able to tell me where I could find it?
Secondly, I’m having trouble opening Sunc3Updater. I’ve run as admin, I’ve turned off anti-virus. Everything. It pops up, says Checking for updates, then just closes.
I’m trying to update my maps and to the latest version of sync3. Any and all help would be greatly appreciated. Thank you!
3.0 APIM Navigation Unit Firmware (Production Release 2017-2018)
(Originally Found On 2017/Some 2018 - Units That Ship with 2 USB Ports on Back)
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-CA or HB5T-14G375-DA or HB5T-14G375-FA
GB5T-14G379-AA
HB5T-14G379-BA
This Worked, But Before you sent this I was trying to do the 3.4 config but that Wasn’t working. Im trying to get the TCU module to reconize Hotspot. will this Firmware make this work? Im also getting Error 2100 in the apim now. I read that a rewrite of Asbuild will fix that but its still there. Thanks for your input! I’m Just trying to understand those packages to learn more.
Do I have to choose the right file according to what I have in this list? The files to choose from are,
I have the HP5T-14G371-CAG USA, 3.4 build 21194, and I uploaded eu navi maps, everything works but I don’t have the fm station logo. can i use this method?
Your APIM may not support the very latest firmware versions, but will support the following, which will give you the 7D0-09 coding. This coding is only for enabling menus in the Sync screen that already exist in the vehicle, like in the IPC, etc. This will not turn on new features, etc.
