US Imported Vehicle Conversion for EU Station Logos
Then you are already there for the logo file. I do not know why your logos do not work as expected. Having a US car imported to EU there are so many settings that can be affected.
I suggest loading your original asbuilt for the APIM and trying one thing at a time.
Where should I get the original for APIM? When I do it, what’s next?
https://www.motorcraftservice.com/asbuilt
Enter your VIN, download the asbuilt file. Also print the info on the page, save as PDF or print it.
Use the info to set one line at a time back to the values (7D0-xx-xx) of the original asbuilt and check the DTC’s. Remember to do a master reset or cycle the ignition for the settings to take affect.
Is it for APIM from 7D0-XX-XX? because I only have one * .ab file and PCM modules and BCE modules. Can you tell what the rest are from?
Scroll down to 7DO section. That is the APIM.
ALL of the vehicle modules are listed in this document.
Ok. If there is time, I will check it :wink:
