US Imported Vehicle Conversion for EU Station Logos
NOTE: CyanLabs does not support changing regions.
For those of you looking to enable station logos on your Sync equipped US vehicle imported to EU, here are 2 threads illustrating changes needed for the ACM and APIM. As I understand, the settings in the threads allege that you will have EU frequencies and RDS. There are mentions of updating the firmware for the ACM as well as replacement.
You need to change the asbuilt data for the ACM:
727-04-01 xXxx xxxx xxxx
Change “X” for Tuner Region: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
For reference, here is the link to the APIM AsBuilt Database:
https://cyanlabs.net/ford-apim-asbuilt-db/
For the radio logos, see the links to the FORScan Forum threads…if you know of other helpful articles I will add them below.
https://forscan.org/forum/viewtopic.php?t=4346
https://www.forscan.org/forum/viewtopic.php?t=4989
https://forscan.org/forum/viewtopic.php?f=16&t=13357
Another resource at Ford Owners Club, page 37 of the topic.
EDIT: AE logo file works best with Sync 3.4.20136. If you have updated to the not publicly released 3.4.20196 there will be a lot of missing logos with AE. There is a corresponding updated logo file named 1U5T-14G658-AF for Sync 3.4.20196.
http://ivsubinaries.azureedge.net/swparts/1U5T-14G658-AF_1598633324000.TAR.GZ
I will try to enable it again but tried it before.
Somewhere in the forum is a description of how to do it. I used this https://cyanlabs.net/ford-apim-asbuilt-db/
I already have the frequencies and the radio, because I had 3.4_19101 before.
If you are looking to turn on Enhanced DAB, 4605 xx.
I will test all options. I hope something will turn on. Do I have to reset APIM after each change?
Just cycle the vehicle power. Turn off ignition, wait a minute, then turn it back on.
Unfortunately, nothing changes. Will I change to 4405 or 4605 the same all the time.
I don’t know what is anymore.
Maybe something wrongly loaded.
Your vehicle is still using US ACM settings.
I have it set to 3 all the time.
Then there is another item not configured. You still have the US menu showing on the ACM.
727-01-01 Xxxx xxxx xxxx
Needs to be 9
Internal SDARS & APIM type (gen1/gen2) & EFP (CAN/LIN) & APIM
0=Int SDARS enabled & APIM gen2 & EFP CAN based & APIM not available
1=Int SDARS enabled & APIM gen2 & EFP CAN based & APIM available
2=Int SDARS enabled & APIM gen2 & EFP LIN based & APIM not available
3=Int SDARS enabled & APIM gen2 & EFP LIN based & APIM available
4=Int SDARS enabled & APIM gen1 & EFP CAN based & APIM not available
5=Int SDARS enabled & APIM gen1 & EFP CAN based & APIM available
6=Int SDARS enabled & APIM gen1 & EFP LIN based & APIM not available
7=Int SDARS enabled & APIM gen1 & EFP LIN based & APIM not available
8=Int SDARS disabled & APIM gen2 & EFP CAN based & APIM not available
9=Int SDARS disabled & APIM gen2 & EFP CAN based & APIM available
A=Int SDARS disabled & APIM gen2 & EFP LIN based & APIM not available
B=Int SDARS disabled & APIM gen2 & EFP LIN based & APIM available
C=Int SDARS disabled & APIM gen1 & EFP CAN based & APIM not available
D=Int SDARS disabled & APIM gen1 & EFP CAN based & APIM available
E=Int SDARS disabled & APIM gen1 & EFP LIN based & APIM not available
F=Int SDARS disabled & APIM gen1 & EFP LIN based & APIM available
727-01-01 xXxx xxxx xxxx
Needs to be either C, D, E, or F
HD Radio (enabled/disabled) & DAB Tuner (avail/not avail) & SWC Audio:CAN-SWC (avail/not avail) & CGEA Version (1.2/1.3)
0=HD radio enabled & DAB not avail & SWC not avail & CGEA 1.3
1=HD radio enabled & DAB not avail & SWC not avail & CGEA 1.2
2=HD radio enabled & DAB not avail & SWC avail & CGEA 1.3
3=HD radio enabled & DAB not avail & SWC avail & CGEA 1.2
4=HD radio enabled & DAB avail & SWC not avail & CGEA 1.3
5=HD radio enabled & DAB avail & SWC not avail & CGEA 1.2
6=HD radio enabled & DAB avail & SWC avail & CGEA 1.3
7=HD radio enabled & DAB avail & SWC avail & CGEA 1.2
8=HD radio disabled & DAB not avail & SWC not avail & CGEA 1.3
9=HD radio disabled & DAB not avail & SWC not avail & CGEA 1.2
A=HD radio disabled & DAB not avail & SWC avail & CGEA 1.3
B=HD radio disabled & DAB not avail & SWC avail & CGEA 1.2
C=HD radio disabled & DAB avail & SWC not avail & CGEA 1.3
D=HD radio disabled & DAB avail & SWC not avail & CGEA 1.2
E=HD radio disabled & DAB avail & SWC avail & CGEA 1.3
F=HD radio disabled & DAB avail & SWC avail & CGEA 1.2
Needs to be 3.
727-04-01 xxxx xxXX XXxx
Needs to be the country code for Poland (504C)
727-04-01 x*xx xxxx xxxx Tuner Region: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
727-04-01 xxx* xxxx xxxx SDARS Region: 0=unconfigured, 1=U.S., 2=CANADA, 3=no content
727-04-01 xxxx x*xx xxxx SDARS Data Services: 0=unconfigured, 1=Data Services, 2=no Data Services
727-04-01 xxxx xx** **xx Country Code: 5553=U.S.
These are in the articles I posted.
I will see and let you know. Can I do this in forscan?
A bit strange because I have a car for a year and everything was ok
What do I have to set experimentally here?
If I’m in Poland, what should be here?
|727-04-01 |xxx* |xxxx |xxxx |SDARS Region: 0=unconfigured, 1=U.S., 2=CANADA, 3=no content|
|727-04-01 |xxxx |x*xx |xxxx |SDARS Data Services: 0=unconfigured, 1=Data Services, 2=no Data Services|
I changed a bit but nothing changes anyway.
0 for both, you probably have no satellite radio…
Do you actually have DAB in Poland? if yes then C, if no then 8.
There is DAB in Poland, but my car is probably not equipped.
I had 3.4_19101 F8, I uploaded 3.4_20196 F9 using Syn3 Updater. What do you suggest ?
Update 1U5T-14G658-AF for Sync 3.4.20196.
Can such an error be the reason that I cannot turn on the station’s logo in the radio settings?
APIM has incomplete or incompatible configuration.
APIM U2101:00-0B
Code: U2101 - Control Module Configuration Incompatible
Status:
  • DTC present at Time of Request
  • Malfunction Indicator Lamb is Off for this DTC
Most likely you have something configured as CGEA rather than C1MCA. Look for those selections.
But I have this upload. As seen on the cyanlabs pendrive.
Where to look for it?
