Warning received
Hi,
Just prepare the usb stick and received a warning about what I’ve select on region, as don’t match with curent region. Any ideea ?both selected is EU
And other things is my software version is 3.0.23219 not found in the list on car config. Just added manualy / any issue here?
Old SYNC Version: 3.0.23219
New SYNC Version: 3.0.23219
Hello.
If the selected target region matches your unit’s, then it’s ok. About the latest 3.0 not being listed, that’s also “ok”… Just select any other 3.0 and you will be fine.
