X40 upgrade
I know I had that radio which would not work in a 2015 F-150 Platinum with Sony sound system. The radio would never turn on. I have a K series APIM. You will need to source one of the 18D832 radios above for this to work in your F-150. I ended up with a -CH version which worked perfectly once the wiring and programming was completed. Although probably not necessary, I recommend updating the firmware for the APIM and ACM to the latest versions while performing this upgrade.
