I’m in the process of updating to 3.4 and it’s been going for an hour and a half now. How long does this normally take?
Old SYNC Version: 1.1.15349
Not as of right now.
Syn3 Updater Version: Newest version
None yet
NA non nav like 20 minutes if your usb is good
I don’t think Sync 3 works on a 2046 Escape…2016?
I don’t see a listing for that Sync 3 version. Are you sure this is Sync 3 or is this a Sync 1 variant with a 4 inch screen, being non-nav.
If this is a Sync 3 version, 1.1.xxxxx, you will likely need to split the installation because the APIM is running out of memory, or disk space. This is common with Sync Non-Nav versions. Even Ford accounts for this in their own autoinstall scripting for the later Sync 3.0 Non-Nav updates. The early versions of Sync 3, like yours, can be problematic to upgrade, but will upgrade nonetheless.
Yes, 2016. Lol. I got it to install, only issues now is it keeps popping up saying usb hub is not supported and to remove the usb. The usb isnt in there.
You need to replace the usb hub to remove that message and use car play, android auto will work with that message.
Since this is no longer an issue, I’m closing the thread.
