What is your SYNC Region? NA
What is your current SYNC Version? 3.4.21020
Do you have Navigation? Yes
Is there a way to upgrade Maps on a 2020 using the CyanLabs tool?
Yes, change the branch in settings to CI, then try upgrading only maps. Should generate usb to autoinstall maps, but it will take way longer.
This is being tested, and we have already success stories.
Thanks! I will give it a try!
This worked on my 2020 Ford Explorer ST. Did this after the 21020 update.
