2013 F150 retrofit sync3 APIM config
Good day,
Ordered an 4” to 8” sync3 from ebay.
Installed it and it was supposed to be preprogrammed but nothing was working.
I managed to do some adjustments and get it to work somewhat but there are still some issues and i hope you could help me out.
  1. Under climate everything is blank as as far as I understand that wont be able to work with my 2013 F150 XLT(?)
  2. When i change the volume it shows me the level of volume but when i adjust the heat or fan i dont get a level indicator whatsoever for heat/fan level.
  3. Sometimes when i start my truck, plug in my iphone and carplay works, but when i do a put stop at a gas station and turn off the truck for 5min and come back and plug my phone in again carplay pops up and i press play on ytmusic/spotify it will continue to play the radio station and not from car play.
  4. I have a feeling the unit never shots off completely… i turn off the truck, pull the key out, open the door and the unit shuts off, shows splash screen, music stops, splashscreen turns off and goes black and 5 seconds after the music continues to play from a radio station and stops after a few seconds but the backlight of the unit is still on(visible at night)
  5. Under audio/source i dont have siriusxm as an option, i have am, fm, cd and bluetooth.
  6. I can preset radio stations to slots but when i click on the slots to select them after i save them, it wont change to that station(but i do hear a beep)
My APIM:
7D0-01-01: 0A21 8280 0006
7D0-01-02: 028B 0204 8BF8
7D0-02-01: 0443 4100 0062
7D0-02-02: 0202 8000 005F
700-02-03: 0000 DC
700-03-01: 0000 0103 00DF
700-04-01: 0100 0001 00DE
7D0-04-02: 0001 DE
7D0-05-01: 1A68 1A68 3819
7D0-05-02: A482
7D0-06-01: 805E
7D0-07-01: 4600 3300 0058
7D0-07-02: 0000 029A 007C
7D0-07-03: 0056 5692 001F
7D0-07-04: C8AA
7D0-08-01: 0000 0000 00E0
7D0-08-02: 0000 0000 01E2
Old SYNC Version: 0.0
You’ll have to research a vehicle with the same combination /specs as the one you’ve just built, grab its VIN number and get the asbuilt for that.
Look for a 2016 F150 on Carfax with the same trim and feature, that was the first year for Sync3 in the F150 it will be closest to what you have.
Thank you, i will give the 2016 F150 a try and update if i have success.
No sucess, tried different vehicles and fixed a few flaws but my climate controlls still dont indicate or at least changes in fan spead/heat
Please post the model number of the APIM, and an Interrogator file of the APIM.
