2013 F150 Sync 1 -> Sync 3 Issues
Installed a sync 1 to sync 3 kit on a 2013 F150, got everything to work besides the climate control buttons on the control panel. The sync 3 APIM communicates and shows the correct climate settings and responds however the control panel doesn’t light up when the specific climate buttons are being pressed.
The control panel is from a 2013 King Ranch, that’s the only issue I can think of. The climate control buttons on the panel work, however the lights inside the control panel do not work or turn on.
Edit : I believe it’s actually a lariat control panel
Old SYNC Version: 1.0.00
New SYNC Version: 3.4.000
Could be running into a firmware/calibration problem with the FCIM or the APIM config isn’t quite right.
