No problem at all, they’re all pretty much just minor annoyances to me and I haven’t been too bothered using the physical climate controls and such.
I’ll be sure to correct that difference you mentioned in FORScan tomorrow. As I said before in my original post, this is my first time using FORScan so I’m not particularly surprised I messed up in a few spots ![]()
I’m looking at picking up a JK2T-14G371-FDB APIM with a 06/06/18 MFG date and installing a new, proper GPS antenna at the same time I install the new unit. The pictures of it seem to match up with a gen 3 2018.5 unit looking at your post APIM Firmware Production Releases and the CyanLabs hardware database has 40 entries unanimously stating it’s a 64GB nav-enabled unit. The listing says it comes from a MK8 Ford Fiesta, although I don’t think that makes much of a difference.
Do you think I’ll run into any issues with this unit once I’ve done a fresh install of 23088 + master reset with the proper asbuilt configuration applied?
