APIM Firmware Production Releases
Sync 3 APIM Firmware Production Releases (NA)
NOTE: This listing is representative of the production release files for North America. Use the Calibration File Region listing below to determine the proper -14G375- calibration file for your region.
POST-MY18.5:
3.4 APIM NAV & NON-NAV Unit Firmware (Production Release, 2021+ L Series)
Strategy (F188): 1U5T-14G374-EM (7/13/2022)
Calibration (F124): 1U5T-14G375-DA (NAV) / 1U5T-14G375-CA (NON-NAV)
ECU Configuration/Illumination Strategy (F16B): 5U5T-14G379-BC (6/16/2020)
3.4 APIM NAV & NON-NAV Unit Firmware (Production Release, 2021 L Series)
Strategy (F188): 1U5T-14G374-EL (1/2/2021)
3.4 APIM NAV & NON-NAV Unit Firmware (Production Release, 2020 L Series)
Strategy (F188): 1U5T-14G374-EK (6/13/2020)
Strategy (F188): 1U5T-14G374-EH (9/25/2019)
Calibration (F124) : 1U5T-14G375-DA (NAV) / 1U5T-14G375-CA (NON-NAV)
ECU Configuration/Illumination Strategy (F16B): 5U5T-14G379- BB (9/25/2019)
3.4 APIM NAV & NON-NAV Unit Firmware (Production Release, 2019, Later K Series)
Strategy (F188): 1U5T-14G374-EE (6/11/2019)
ECU Configuration/Illumination Strategy (F16B): 5U5T-14G379- BA (6/11/2019)
3.2/3.3 APIM NAV & NON-NAV Unit Firmware (Production Release, 2018.5, Late J thru K Series)
Strategy (F188): 1U5T-14G374-DA (6/27/2018)
ECU Configuration/Illumination Strategy (F16B): JB5T-14G379-BA (6/7/2018)
PRE-MY18.5:
3.0 APIM NAV & NON-NAV Unit Firmware (Production Release, 2017-Pre-2018.5, H thru Early J Series)
(Originally Found On 2017/Early 2018 Units That Ship with 2 USB Ports on Back)
Strategy (F188): HB5T-14G374-CA
Calibration (F124): HB5T-14G375-DA or HB5T-14G375-FA (NAV) / HB5T-14G375-CA (NON-NAV)
ECU Configuration/Illumination Strategy (F16B): HB5T-14G379-BA
3.0 APIM NAV Unit Firmware (Production Release, 2016-Early 2017, G thru Early H Series)
Strategy (F188): GB5T-14G374-CA or GB5T-14G374-CB
Calibration (F124): GB5T-14G375-DA or GB5T-14G375-FA
ECU Configuration/Illumination Strategy (F16B): GB5T-14G379-BA
3.0 APIM NON-NAV Unit Firmware (Production Release, 2016-Early 2017, G thru Early H Series)
Strategy (F188): GB5T-14G374-AF (Use GB5T-14G374-CD to update.)
Calibration (F124): GB5T-14G375-BA or GB5T-14G375-BB
Calibration File Region:
xxxx-14G375-A*.vbf 8GB / 16GB EU without NAV
xxxx-14G375-B*.vbf 8GB / 16GB NA without NAV
xxxx-14G375-C*.vbf 8GB / 16GB ROW without NAV
xxxx-14G375-D*.vbf 32GB NA with NAV (Telenav)
xxxx-14G375-E*.vbf 32GB CHINA with NAV (Telenav)
xxxx-14G375-F*.vbf 32GB ANY region with NAV (US Export vehicles) (Telenav)
xxxx-14G375-G*.vbf 32GB ROW with NAV (NNG)
xxxx-14G375-H*.vbf 64GB EU with NAV (Telenav)
xxxx-14G375-J*.vbf 32GB TURKEY with NAV (Telenav)
xxxx-14G375-K*.vbf 32GB UAE with NAV (NNG)
Thanks to @AuRoN for the Calibration File Region info.
Sync 3 APIM Hardware Identification:
Generation 1: 2016-2017, two USB connectors, metal FAKRA for GPS.
Generation 2: 2017-2018, one USB connector, two holes in the case, metal FAKRA for GPS.
Generation 3: 2018.5, one USB connector, one hole in the case, plastic FAKRA for GPS.
Generation 4: 2019, one USB connector, one hole in the case, plastic FAKRA for GPS.
Generation 4: 2020, one USB connector, one hole in the case, plastic FAKRA for GPS.
