2016 F150, sync 3 updated to 3.0.23219 and updated usb to correct model.
2016 F150, sync 3 updated to 3.0.23219 from ford and updated oem usb to correct carplay model, but lost voice regognition and carplay will not work. I downloaded 3.4 latest version and stated download completed remove usb, but still shows 3.0.23219 version on about info on vehicle. I also used a 32gb usc 2.0.
Log Records are:
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2005-10-16” xsi:schemaLocation=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0 ModuleSnapshot.xsd”>
<p:VIN>1FTEW1EG2GKE39585</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNC</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“e0175108”/>
<d2p1:DTC DTCValue=“f000040b”/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseJR3T-14G381-AY</d2p1:Response>
</d2p1:DID>
d2p1:Response474235542d3134473432322d434a00000000000000000000474235542d3134473432312d434a00000000000000000000474235542d3134473432342d4348000000000000000000004a5233542d3134473339312d4345000000000000000000004a5233542d3134473432332d434200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Responseb7aef79b</d2p1:Response>
</d2p1:DID>
d2p1:Responseebe8cf6c</d2p1:Response>
</d2p1:DID>
d2p1:Response2a2a040600028906048a</d2p1:Response>
</d2p1:DID>
d2p1:Response55530103c402028000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response0000010300</d2p1:Response>
</d2p1:DID>
d2p1:Response01000001000001</d2p1:Response>
</d2p1:DID>
d2p1:Response1a681a6838a4</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response46003300000000029a000056569400c8</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-GB5T-14G371-AF</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGJ5T-14G380-BC</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGJ5T-14G371-CFC</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseVV32XKX4</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G374-AF</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Response88:c2:55:50:7d:0e</d2p1:Response>
</d2p1:DID>
d2p1:Response88:c2:55:50:7d:0f</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“ASCII” didType=“ECU Cal-Config Part Number” didValue=“F10A” responseLength=“24”>
</d2p1:DID>
<d2p1:DID didFormat=“ASCII” didType=“ECU Cal-Config #2 Part Number” didValue=“F16B” responseLength=“24”>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2005-10-16T15:48:29+00:00” RAM=“1234567” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/usb0/” total=“29G” available=“29G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Old SYNC Version: 1.0
New SYNC Version: 3.0.23219
At one point it stated USB not supported, and still has voice regognition error and will not work.
Syn3 Updater Version: 3.13.3.0
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2005-10-16" xsi:schemaLocation="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0 ModuleSnapshot.xsd">
<p:RequestRole>
</p:RequestRole>
<d2p1:DTC DTCValue="e0175108"/>
<d2p1:DTC DTCValue="f000040b"/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AY</d2p1:Response>
</d2p1:DID>
<d2p1:Response>474235542d3134473432322d434a00000000000000000000474235542d3134473432312d434a00000000000000000000474235542d3134473432342d4348000000000000000000004a5233542d3134473339312d4345000000000000000000004a5233542d3134473432332d434200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>b7aef79b</d2p1:Response>
</d2p1:DID>
<d2p1:Response>ebe8cf6c</d2p1:Response>
</d2p1:DID>
<d2p1:Response>2a2a040600028906048a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>55530103c402028000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000010300</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01000001000001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1a681a6838a4</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>46003300000000029a000056569400c8</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-AF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GJ5T-14G380-BC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GJ5T-14G371-CFC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>VV32XKX4</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-AF</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>88:c2:55:50:7d:0e</d2p1:Response>
</d2p1:DID>
<d2p1:Response>88:c2:55:50:7d:0f</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2005-10-16T15:48:29+00:00" RAM="1234567" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="29G" available="29G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</p:Node>
Going from Sync 3 V1.0 to 3.0.23219 is a 2 step process, and since you missed a step CP does not work. However, going to Sync 3.4 this is not necessary.
Your post states you upgraded to 3.0.23219 and CP does not work. But you indicate you downloaded Sync 3.4 and that failed? If you did not use the Syn3 Updater to reformat the APIM, of course it would fail.
So where are you now? Still on 3.0.23219 and no CP?
Where do you want to be?
Hi F150Chief and thanks for your time and support. I don’t have a preference between 3.02 or 3,4 version, but mainly want voice recognition and CarPlay to work so whichever path is best. My system states 3.0 build 23219 currently loaded. When I used the Sync 3 updater I cleared flash drive then went through updater steps and then plugged flash in truck. It stated upload complete but it did not.
Your guidance on how best to resolve is greatly appreciated!
If you want to stay at Sync 3.0, you will need to download and run a previous version of Sync, version 2.2. This will load the CP feature for Sync 3.0. From there you will upgrade back to the latest Sync 3.0 version 23219.
These files are installed on the APIM:
GB5T-14G422-CJ
GB5T-14G421-CJ
GB5T-14G424-CH
JR3T-14G391-CE
JR3T-14G423-CB
JR3T-14G381-AY
Be aware this is an older APIM, GJ5T-14G371-CFC, and can be prone to issues upgrading to Sync 3.4.
See your PM…
