2016 F150 Sync 3 Upgrade from 3.2.16074 to 3.3.19052 Mem ERR 03
I have been trying to update my software version with no success, it completes there first portion of the install and then fails during the second with a Mem ERR 03. I tried using the tool to delete Grace Notes to free up memory and have run the interrogator to check memory but when the tool tries to read the xml file in step 3 it fails to read it and says contact CYAN. Below is the xml file minus the VIN. Is memory still my issue? Suggestions on next steps. I have tried using both the SyN3 updater method to create the USB drive as well as the Ford Update site. The thumb drive I am using is a 32 GB drive formatted to exfat and the file structure looks like it is supposed to when unzipped.
Suggestions?
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2021-12-07” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN></p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNC</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseHB5T-14G381-AJ</d2p1:Response>
</d2p1:DID>
d2p1:Response484235542d3134473339312d424500000000000000000000484235542d3134473338362d414841000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response96d28823</d2p1:Response>
</d2p1:DID>
d2p1:Responsed6f4d44a</d2p1:Response>
</d2p1:DID>
d2p1:Response2a2a0406000089060482</d2p1:Response>
</d2p1:DID>
d2p1:Response55530103c402028000000005</d2p1:Response>
</d2p1:DID>
d2p1:Response0000010300</d2p1:Response>
</d2p1:DID>
d2p1:Response010014010e0001</d2p1:Response>
</d2p1:DID>
d2p1:Response1a681a683d54</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response47003300000000029a000056569400c8</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHP5T-14G380-AA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHP5T-14G371-BAG</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G375-BA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseVV8V006T</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Response50:65:83:31:31:33</d2p1:Response>
</d2p1:DID>
d2p1:Response50:65:83:31:31:34</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2021-12-07T18:42:26+00:00” RAM=“1275432960” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/dev/hd0t180” total=“1601514496” available=“8908768”/>
<d2p1:PartitionHealth type=“/dev/hd0t181” total=“756848640” available=“2097120”/>
<d2p1:PartitionHealth type=“/dev/hd0t177” total=“37336064” available=“2097152”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Navigation Variant: No
Old SYNC Version: 3.2.16074
New SYNC Version: 3.3.19052
Mem Err 03
Syn3 Updater Version: 2.10.6.0
Version: 3.2.16074
; CyanLabs Syn3Updater 2.10.6.0 Stable - Autoinstall Mode - Sync 3.4.21265 NA
Item1 = GRACENOTES - 4U5T-14G423-CC_1615429225000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-CC_1615429225000.TAR.GZ
Item2 = VOICE - 5U5T-14G391-CP_1626959995000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-CP_1626959995000.TAR.GZ
Item3 = APPS - 5U5T-14G381-EU_1634769242000.TAR.GZ
Open3 = SyncMyRide\5U5T-14G381-EU_1634769242000.TAR.GZ
Follow this tutorial. You need to delete Gracenotes first.
Tutorial: Sync 3.4 NON-NAV APIM: Failure to Update to Newer Version Sync 3.4 - Ford / Guides & Info - CyanLabs Official Community
Thanks, I did run the tool to delete Grace Notes by creating the USB etc. Is the interrogator Xml showing that it is still present? I can run it again and see if that helps.
Gracenotes is not present. However, you are on Sync 3.0, not Sync 3.2. You will need to reformat the unit, not use autoinstall. Configure the Syn3 Updater for the present version (old version) of 2.0.16074, or just Sync 3.0.
Installed:
HB5T-14G381-AJ
HB5T-14G391-BE
HB5T-14G386-AHA
HB5T-14G381-AJ 555Mb Sync3 v2.0.16074 14.03.2016
Thank you, I will do that and let you know what happens.
Worked like a charm! Thank you. I went ahead and upgraded all the way to 3.4.21194 and had absolutely no issues. Took less then 10 minutes to complete.
