2016 f150 sync 3 version 1.0.15139 to 2.2
ok thanks so just remove the gracenotes file from syncmyride folder and from autoinstall and then proceed as usual?
i’m assuming after i will install gracenotes separately?
Just remove the 2 lines from the autoinstall file. Make sure the numbering is correct. You can leave the file on the USB, it won’t matter.
You will need to remove the Gracenote file from the APIM first by running the Gracenote Removal in the Syn3 Updater. This will free up more space on the APIM for the update. You can add the Gracenote file back to the APIM after the update.
did this and android auto setting is now there. just waiting on the new module for carplay. will let you know
I’ve marked this as resolved since the original concern was addressed and you got Android Auto working.
There’s no reason for CP not working from the Sync3 side of things.
