The only setting I am aware of is this…The NAV Repeater function affects you nav display in the IP, so be careful what you select there.
7D0-01-02 xxxx x*xx xxxx
Mode Man Icon [Climate] (MMI), Climate Control Type (CCT), Surround Sound Available in Occupancy Mode (SSA), Nav Repeater Format (NRF)
0=MMI Disabled, CCT Automatic, SSA Available, NRF Motorola format
1=MMI Disabled, CCT Automatic, SSA Available, NRF Intel format
2=MMI Disabled, CCT Automatic, SSA Not Available, NRF Motorola format
3=MMI Disabled, CCT Automatic, SSA Not Available, NRF Intel format
4=MMI Disabled, CCT Manual, SSA Available, NRF Motorola format
5=MMI Disabled, CCT Manual, SSA Available, NRF Intel format
6=MMI Disabled, CCT Manual, SSA Not Available, NRF Motorola format
7=MMI Disabled, CCT Manual, SSA Not Available, NRF Intel format
8=MMI Enabled, CCT Automatic, SSA Available, NRF Motorola format
9=MMI Enabled, CCT Automatic, SSA Available, NRF Intel format
A=MMI Enabled, CCT Automatic, SSA Not Available, NRF Motorola format
B=MMI Enabled, CCT Automatic, SSA Not Available, NRF Intel format
C=MMI Enabled, CCT Manual, SSA Available, NRF Motorola format
D=MMI Enabled, CCT Manual, SSA Available, NRF Intel format
E=MMI Enabled, CCT Manual, SSA Not Available, NRF Motorola format
F=MMI Enabled, CCT Manual, SSA Not Available, NRF Intel format
