Ok, good luck with that.
While you create the USB, read the tutorial you need to follow: Easily Update SYNC 3 Using Our Automated Method - CyanLabs , the Updating (Downgrade Mode) section.
Open the updater and go tho the setup tab. Fill out the config at the top as 3.4 21194, North America & Canada, Navigation Variant: Yes. Save the config.
Go to the update tab. (The house) Select the following…
i just got you last instructions, will try to follow and report back,thank you.
Hello guys, i have also facing the same problem , i have ford edget 2017 and went according to the instruction of selecting nav. and the other steps, now its updated on my car except the Nav is not working, do you think by master reset will solve this issue, if not , shall i download again the update on my USB or ishall use the same USB file to upgrade ? by the way, i’m living in Middle east thank you
Thank all who were involved in helping me see my mistake,followed F-150Chief and Sandmans instructions to a tee.Everything is working perfectly. Many thanks again. Expert advise. Thank you for your patience.Kingfiss
Did you make the region and navigation settings in the APIM asbuilt with FORScan?
Don’t know what step exactly you mean, but all the steps that explained in the video, I followed, I selected Middle East and activated the Nav bar. Before i download it. Will you please screenshot this step?so I know exactly what you mean .thanks
You need to make the asbuilt changes…You need to change the country code in the APIM to the country you are presently in and change the map type to NNG.
APIM Asbuilt Settings:
The country information in the APIM As Built needs to be changed:
from 7D0-02-01 5553 xxxx xxxx
to 7D0-02-01 XXXX xxxx xxxx
This setting changes the country from US to your country code.
When changing from NA to ROW (NNG) maps, the Navigation Map Type will need to be changed from Telenav to NNG. (Central America, Caribbean, India and Sri Lanka, Israel, Middle East, North Africa, South Africa, South East Asia)
7D0-01-02 x*xx xxxx xxxx
USB2, Navigation Map Type (Telenav/NNG), Rear Electronic Feature Panel (REFP) (Rear EFP with Rotary Volume Knob)
0=USB2 Disabled, Navigation Disabled, Rear EFP Disabled
1=USB2 Disabled, Navigation Disabled, Rear EFP Enabled
2=USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Disabled
3=USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Enabled
4=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Disabled
5=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Enabled
If you have a setting of ‘2’, use a setting of ‘4’.
If you have a setting of ‘3’, use a setting of ‘5’.
This topic was automatically closed 9 days after the last reply. New replies are no longer allowed.
