Updated to 3.0.20204 (Unsure of previous version) using Ford portal a short while back but overnight last week the Sync wouldn’t connect to anything other than Android Auto, after disconnecting the phone (USB & Bluetooth) the Sync will not connect to any source (Including Android Auto) and I also get the following symptoms:
- Loud thud from the speakers (Sub?) as often as every 15 seconds - reboot loop? -This even happens after I have turned the engine off and locked the vehicle
- Can only select another source (other than the radio AM default) during the 15 seconds between ‘thuds’, even this is intermittent
- No volume control
I have tried a master reset and a soft reset? (Power + Forward skip)
I am considering updating to 3.4 from 3.0.20204 to see if it clears the fault but something (The boot loop) makes me think it may be hardware failing and I’d rather not add insult to injury by flashing it badly and causing more problems than I already have…
I was just hoping for some suggestions from a well informed community so if anyone has something they can offer please let me know.
I work early hours so may not be able to respond immediately to any questions.
Interrogator info below:
VIN: REMOVED
Version JR3T-14G381-AX
APIM Model: H1BT-14G371-FEC
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 20G
21/05/2024 19:54:32 +00:00
Partition Type = Free / Total
/fs/usb0/ = 14G / 14G
/fs/tmpfs/ = 127M / 128M
/fs/sd/MAP/ = 4.5M / 1.5G
/fs/sd/MAP/ = 79M / 14G
/fs/Nuance/ = 843M / 15G
/fs/Nuance/ = 7.6M / 1.9G
/fs/Nuance/grace = 6.1M / 1.0G
/fs/rwdata/ = 625M / 1024M
/fs/mp/ = 40M / 1024M
/fs/images/ = 20G / 55G
Installed Packages
JL7T-14G421-BA
JR3T-14G391-AE
JL7T-14G422-BA
JR3T-14G423-AB
APIM AsBuilt
DE00: 086A05DA5002FC4440C2
DE01: 554B0001C08A088028B80005
DE02: 0000010004
DE03: 00001D82010001
DE04: 190819082653
DE05: 80
DE06: 0B0533000000006428000056565F0061
Old SYNC Version: 3.0.20204
New SYNC Version: 3.0.20204
