2019 Lincoln Navigator update started using a USB drive. It did accept the drive and rebooted, but when it came back up it said “Please insert USB Stick…” and it’s there since. I did find another member that had similar issues (maybe not on a Navigator) but they said they did a reset and got it working? I have also tried numerous USB drives (if there is a suggested model, let me know). I used a generic, a Verbatim and a Lexar. None are detected. I even tried a Samsung SSD with an adapter. I have a couple other things to try, but I’m perplexed as it detected the first drive and then, crickets…
I did also see a member suggest to replace the USB hub in the console and to beware of Chinese knock-offs. Is that a true solution?
I"m looking for all available options before I take it to the “stealer-ship” for a couple of recalls, and see if they can also fix this. Figured I better try upgrading before I take it in just in case. Lucky me!
Any and all help is appreciated! I hope to be one more successful upgrade case in the near future!
Thanks in advance!
Old SYNC Version: 3.0.17302
New SYNC Version: 3.0.17302
Stuck at “Please Insert USB Stick…”
Syn3 Updater Version: 2.13.0.0 Stable
Version: 3.0.17302
; CyanLabs Syn3Updater 2.13.0.0 Stable - reformat Mode - Sync 3.4.23188 NA
FILES (12)
[1/26/2025 9:42:51 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: NA - 2025-01-27 - 1737951993
[1/26/2025 9:42:51 PM] Install Mode: Auto-Detect (reformat) Forced: False
[1/26/2025 9:42:51 PM] MY20 Protection: Auto-Detect
[1/26/2025 9:42:51 PM] Formatting USB drive
[1/26/2025 9:42:51 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[1/26/2025 9:43:00 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/26/2025 9:43:00 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[1/26/2025 9:43:00 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/26/2025 9:43:00 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[1/26/2025 9:43:00 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/26/2025 9:43:01 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[1/26/2025 9:43:01 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/26/2025 9:43:04 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[1/26/2025 9:43:04 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/26/2025 9:43:08 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[1/26/2025 9:43:08 PM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 9:43:13 PM] Validate: 4U5T-14G421-CGG_1709608813000.TAR.GZ (Failed!, Downloading)
[1/26/2025 9:43:13 PM] Downloading: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 9:45:48 PM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 9:45:52 PM] Downloaded: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 9:45:52 PM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 9:45:52 PM] Downloading: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 9:48:58 PM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 9:49:04 PM] Downloaded: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 9:49:04 PM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 9:49:04 PM] Downloading: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 9:52:49 PM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 9:52:54 PM] Downloaded: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 9:52:54 PM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 9:52:54 PM] Downloading: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 9:55:24 PM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 9:55:30 PM] Downloaded: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 9:55:30 PM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 9:55:30 PM] Downloading: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 9:57:26 PM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 9:57:32 PM] Downloaded: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 9:57:32 PM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 9:57:32 PM] Downloading: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 9:59:27 PM] Validating: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 9:59:33 PM] Downloaded: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 9:59:33 PM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 9:59:33 PM] Downloading: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:01:14 PM] Validating: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:01:18 PM] Downloaded: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:01:18 PM] Preparing USB drive
[1/26/2025 10:01:18 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/26/2025 10:01:18 PM] Copying: 1u5t-14g386-cb.tar.gz
[1/26/2025 10:01:21 PM] Validating: 1u5t-14g386-cb.tar.gz
[1/26/2025 10:01:21 PM] Copied: 1u5t-14g386-cb.tar.gz
[1/26/2025 10:01:21 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/26/2025 10:01:21 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/26/2025 10:01:21 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/26/2025 10:01:21 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/26/2025 10:01:21 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/26/2025 10:01:21 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/26/2025 10:03:40 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/26/2025 10:04:03 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/26/2025 10:04:03 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/26/2025 10:04:03 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/26/2025 10:07:08 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/26/2025 10:07:42 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/26/2025 10:07:42 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/26/2025 10:07:42 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/26/2025 10:12:38 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/26/2025 10:13:30 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/26/2025 10:13:30 PM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 10:13:30 PM] Copying: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 10:18:09 PM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 10:19:19 PM] Copied: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[1/26/2025 10:19:19 PM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 10:19:19 PM] Copying: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 10:23:34 PM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 10:24:50 PM] Copied: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[1/26/2025 10:24:50 PM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 10:24:50 PM] Copying: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 10:32:13 PM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 10:32:21 PM] Copied: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[1/26/2025 10:32:21 PM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 10:32:21 PM] Copying: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 10:36:02 PM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 10:36:08 PM] Copied: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[1/26/2025 10:36:08 PM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 10:36:08 PM] Copying: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 10:39:14 PM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 10:39:18 PM] Copied: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[1/26/2025 10:39:18 PM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 10:39:18 PM] Copying: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 10:43:08 PM] Validating: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 10:43:18 PM] Copied: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[1/26/2025 10:43:18 PM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:43:18 PM] Copying: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:47:11 PM] Validating: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:47:14 PM] Copied: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[1/26/2025 10:47:14 PM] Generating reformat.lst
[1/26/2025 10:47:14 PM] Generating autoinstall.lst
[1/26/2025 10:47:14 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
