2020 Explorer ST Updating Stuck
I am attempting to update my 3.4.19200 to 3.4.23188 I followed the prompts and confirmed MY20 AutoInstall was needed. I inserted USB to ST. After sometime a restart occured. The Update was still going and I did not interupt. I went into Sync info and Gracenotes and Map has been updated. After waiting for about 2.5 hours on the Updating system screen I shut off the ST, removed USB. All seems to be working well though my SYNC is still on 3.4.19200 I looked at log and see total=25G available 4.3G
Is this not even space? I know on a MY20 it can be touchy. I wanted to confirm my next steps. Thank you!
Old SYNC Version: 3.4.19200
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2023-08-07" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
  <p:VIN>1FM5K8GC8LGB25110</p:VIN>
  <p:RequestRole>
  </p:RequestRole>
  <p:BroadcastDTCType/>
    <d2p1:ECUAcronym name="APIM">
      <d2p1:State>
            <d2p1:Response>5U5T-14G381-CD</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>355535542d3134473339312d434800000000000000000000345535542d3134473432332d434100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>13da3781</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>2676b8bd</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>aa0a010308026b0c048a</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>55530b04b40b5498a8b6c405</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>0006080200</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>000001900b000b</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1abd1aa42e85</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>10</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1b003300000000753000005656910076</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>DS-1U5T-14G371-EH</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G380-EE</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>5U5T-14G371-CKC</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G375-DA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>WYAPG1PC</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G374-EH</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>90:9a:77:57:a5:e9</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>90:9a:77:57:a5:ea</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2023-08-07T18:02:06+00:00" RAM="866213888" vmcuVersion="Vector_VMCU_02.02.20">
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="10M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="13M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="11M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="879M" available="4.2M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="2.6M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.7G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="13M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.0G" available="12M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="1.6G" available="15M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="1.1G" available="10M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="2.5G" available="24M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.0M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="57M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="576M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="144M"/>
      <d2p1:PartitionHealth type="/fs/images/" total="25G" available="4.3G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>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</d2p1:SyncData>
    </d2p1:AdditionalAttributes>
  </p:Node>
</p:OTAModuleSnapShot>
Maybe try going through the Ford website first. They should show 3.4.22251 available for you.
I certainly can try that. I was hoping to go to the newest version of 3.4.23188. I have heard on forums many issues with 3.4.22251. (rwdata bug) Did not want to update to known issues
On the internet you will always hear about people’s problems. The other 99% don’t have a problem so you won’t hear from them.
This is also noted on CyanLabs Syn3 Updater.
WARNING! - There’s an ongoing issue where rwdata partition is getting full, triggering some issues like settings going back to defaults and/or problems with upgrading to a different version. Check these threads for reference and workarounds:
Technical Information from FMods
Package Name: NU5T-14G381-AB
Epoch: 1665525837000
Major Version: 3.4
Build: 22251
I somehow missed this topic, yes that was indeed an issue @mrself was correct.
