Hi all,
My SYNC 3 v. is 3.4.22110 (factory), and Maps F10 (factory). I’m lacking the FM radio station’s logos since i bought the car, and my maps are outdated.
Been doing some reading throughout the community and would like your advice on the best way to perform this update (and possibly get the FM station’s logo’s.
Steps i thought doing are using Syn3 updater with the following config:
1-Europe Region Selected
2-Sync 3.4.22110 (since the voice’s and logo’s are included in this package)
3-F11 (2021) EU (05 2022)
Already checked for MY20 protection and uploaded the xml file to Syn3 updater and it’s “active”, install mode is “Autoinstall” and Forced “No” .
Am I doing everything ok?
Thank you in advance,
Best regards, Ricardo
SYNC Region: Europe
Navigation Variant: Yes
Old SYNC Version: 3.4.22110
New SYNC Version: 3.4.22110
Syn3 Updater Version: Syn3 Updater 2.11.4.0
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2022-10-27" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>xxxxxxxxxxxxxxxxxxx</p:VIN>
<p:RequestRole>
</p:RequestRole>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>5U5T-14G381-EZ</d2p1:Response>
</d2p1:DID>
<d2p1:Response>315535542d3134473432312d424148000000000000000000315535542d3134473432312d424248000000000000000000315535542d3134473432312d424348000000000000000000315535542d3134473432312d424448000000000000000000315535542d3134473432312d424548000000000000000000315535542d3134473432312d424648000000000000000000315535542d3134473432312d424748000000000000000000315535542d3134473432312d424848000000000000000000315535542d3134473432312d424a48000000000000000000315535542d3134473635382d414800000000000000000000345535542d3134473432322d424145000000000000000000345535542d3134473432322d424246000000000000000000345535542d3134473432322d424345000000000000000000345535542d3134473432322d424445000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415300000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>315535542d3134473432342d424b00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>3a46e7da</d2p1:Response>
</d2p1:DID>
<d2p1:Response>44c0e107</d2p1:Response>
</d2p1:DID>
<d2p1:Response>086a019a50027c044282</d2p1:Response>
</d2p1:DID>
<d2p1:Response>504f0b04c08a0890acb8ce04</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000010000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>00001d82390101</d2p1:Response>
</d2p1:DID>
<d2p1:Response>190819082653</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>0b053300000000642800005656680061</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-1U5T-14G371-EK</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GU5T-14G380-FE</d2p1:Response>
</d2p1:DID>
<d2p1:Response>LU5T-14G371-GMF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>NZ9400CC</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>1U5T-14G374-EK</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>a8:e7:7d:c1:ed:0c</d2p1:Response>
</d2p1:DID>
<d2p1:Response>a8:e7:7d:c1:ed:0d</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2022-10-27T14:48:24+00:00" RAM="1014128640" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="892K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.8G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="7.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="21M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="396K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="5.7M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.1G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.7G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.6G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.1G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.4G" available="33M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="857M"/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="89M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="72M" available="332K"/>
<d2p1:PartitionHealth type="/fs/images/" total="54G" available="12G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
