Hi,
I have a bronco sport big bend with an issue of a hard steering wheel due to a U3000 error code
I have beta forscan with an extended license and I tried to flash the firmware again but it’s not found in the database
I’m going to post full logs and attach the screenshots
Please help
===PCM DTC P0073:00-27===
Code: P0073 - Ambient Air Temperature Sensor Circuit A High
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC P0073:00-27===
===PCM DTC U0452:00-2F===
Code: U0452 - Invalid Data Received From Restraints Control Module
Status:
===END PCM DTC U0452:00-2F===
===OBDII DTC P0073-P===
Status:
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0073-P===
===APIM DTC None===
Successful DTC reading, no error codes found
===END APIM DTC None===
===BdyCM DTC B121A:15-0A===
Code: B121A - Keypad Illumination Output
Additional Fault Symptom:
- Circuit Short To Battery Or Open
Status:
Module: Body Control Module
===END BdyCM DTC B121A:15-0A===
===BdyCM DTC B1336:01-0A===
Code: B1336 - Left Front Door External Antenna
- General Electrical Failure
Status:
===END BdyCM DTC B1336:01-0A===
===BdyCM DTC B14E7:08-0A===
Code: B14E7 - Right Front Enhanced Exterior Lighting System
- Bus Signal/Message Failures
Status:
===END BdyCM DTC B14E7:08-0A===
===BdyCM DTC B14E5:08-0A===
Code: B14E5 - Left Front Enhanced Exterior Lighting System
Status:
===END BdyCM DTC B14E5:08-0A===
===BECMB DTC None===
Module: Battery Energy Control Module B
===END BECMB DTC None===
===AWD DTC None===
Module: All Wheel Drive Module
===END AWD DTC None===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===ATCM DTC None===
Module: All Terrain Control Module
===END ATCM DTC None===
===TRM DTC None===
Module: Trailer Module
===END TRM DTC None===
===C-CM DTC None===
Module: Cruise-Control Module
===END C-CM DTC None===
===ABS DTC U0100:00-2F===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
Module: Antilock braking system
Freeze Frame :
-GLOBTIM: 34841631 s - Global real time
-TOTDIST: 22662.0 km - Total Distance
-MAINECUV: 12.00 V - Main ECU voltage supply
===END ABS DTC U0100:00-2F===
===ABS DTC U0452:00-2F===
Status:
Freeze Frame :
-GLOBTIM: 34841627 s - Global real time
-OUTTMP: 21 °C - External Temperature From Sensor
===END ABS DTC U0452:00-2F===
===TCU DTC None===
Module: Telematic Control Unit Module
===END TCU DTC None===
===RCM DTC B0050:13-AF===
Code: B0050 - Driver Seatbelt Sensor
- Circuit Open
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Restraint Control Module
Freeze Frame :
-GLOBTIM: 34842356 s - Global real time
===END RCM DTC B0050:13-AF===
===RCM DTC B0052:13-AF===
Code: B0052 - Passenger Seatbelt Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B0052:13-AF===
===RCM DTC B0070:13-AF===
Code: B0070 - Driver Seatbelt Pretensioner A Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B0070:13-AF===
===RCM DTC B0072:13-AF===
Code: B0072 - Passenger Seatbelt Pretensioner A Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B0072:13-AF===
===RCM DTC B007E:13-AF===
Code: B007E - Driver Seatbelt Pretensioner C Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B007E:13-AF===
===RCM DTC B00B5:13-AF===
Code: B00B5 - Driver Seat Track Position Restraints Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B00B5:13-AF===
===RCM DTC B00C5:13-AF===
Code: B00C5 - Passenger Seat Track Position Restraints Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B00C5:13-AF===
===RCM DTC B1193:00-AF===
Code: B1193 - Crash Event Storage Full and Locked
Status:
Freeze Frame :
-GLOBTIM: 34842350 s - Global real time
===END RCM DTC B1193:00-AF===
===RCM DTC B1404:13-AF===
Code: B1404 - Driver Side Airbag Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B1404:13-AF===
===RCM DTC B1405:13-AF===
Code: B1405 - Driver Side Curtain Deployment Control 2
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B1405:13-AF===
===RCM DTC B1407:13-AF===
Code: B1407 - Passenger Side Airbag Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B1407:13-AF===
===RCM DTC B1408:2B-D0===
Code: B1408 - Passenger Side Curtain Deployment Control 2
- Signal Cross-Coupled
Status:
- Test not complete
===END RCM DTC B1408:2B-D0===
===RCM DTC B140A:13-A7===
Code: B140A - Second Row Driver Side Airbag Deployment Control
- Circuit Open
Status:
===END RCM DTC B140A:13-A7===
===RCM DTC B140B:13-A7===
Code: B140B - Second Row Passenger Side Airbag Deployment Control
- Circuit Open
Status:
===END RCM DTC B140B:13-A7===
===RCM DTC B140C:13-AF===
Code: B140C - Second Row Driver Side Seatbelt Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B140C:13-AF===
===RCM DTC B1414:13-AF===
Code: B1414 - Driver Side Restraints Sensor 2
- Circuit Open
Status:
Freeze Frame :
-GLOBTIM: 34842351 s - Global real time
===END RCM DTC B1414:13-AF===
===RCM DTC U0154:00-AF===
Code: U0154 - Lost Communication with Restraints Occupant Classification System Module A
Status:
Freeze Frame :
-GLOBTIM: 34842353 s - Global real time
===END RCM DTC U0154:00-AF===
===HVAC DTC U0401:00-0A===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC U0401:00-0A===
===GSM DTC None===
Module: Gear Shift Module
===END GSM DTC None===
===PSCM DTC U3000:49-8A===
Code: U3000 - Control Module
- Internal Electronic Failure
Status:
Module: Power Steering Control Module
===END PSCM DTC U3000:49-8A===
===PSCM DTC U3000:66-8A===
- Signal Has Too Many Transitions/Events
Status:
===END PSCM DTC U3000:66-8A===
===ACM DTC B1A01:13-0B===
Code: B1A01 - Speaker #1
- Circuit Open
Status:
Module: Audio Control Module
===END ACM DTC B1A01:13-0B===
===ACM DTC B1A04:13-0B===
Code: B1A04 - Speaker #4
- Circuit Open
Status:
===END ACM DTC B1A04:13-0B===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC U0424:00-8A===
Code: U0424 - Invalid Data Received From HVAC Control Module
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0424:00-8A===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===IPMA DTC U0401:86-AF===
- Signal Invalid
Status:
Module: Image Processing Module A
===END IPMA DTC U0401:86-AF===
===IPMA DTC U0452:86-AF===
- Signal Invalid
Status:
===END IPMA DTC U0452:86-AF===
(OK) [17:37:53.811] PSCM Module firmware update has been started
(WARN) [17:37:53.821] Reading vehicle info...
(WARN) [17:38:05.097] Downloading firmware files from the Internet...
(ERR) [17:38:10.230] Downloading LX6C-14D007-DBC: File not found
(OK) [17:38:23.494] Service procedure completed successfully.
