3.0.2024 Isn’t a option on the updater
doesn’t matter, just type it manually.
You can use any 3.0.xxxx from the list, or input it manually, the results will be the same.
Also, this will be fixed in a future release since it has already been identified and solved.
How big of usb will i need for newest update with maps? 32 isnt enough
32GB is definitely enough.
