Hi, I updated my 2016 F-150 from 3.0 Build 18093 to 3.4 Build 22110. I realized that after I had updated I clicked the wrong box. On the second step I checked NA 3.4.221100 No Maps, didn’t see the 2.20 (2020) and 1.19 (2019) option at the time. Now im upgraded to 3.4.22110 and have the nav error. I was wondering how I could fix this problem. I tried downloading the Sync 3 Updater (2.11.4.0) but couldn’t find a tutorial that used the updated Updater so that’s why I did it manually. Any help would be appreciated, Thanks
Navigation Variant: Yes
Old SYNC Version: 3.0.18093
New SYNC Version: 3.4.22110
Navigation Fault
Also used the Updater and selected just maps, put in that I was on 3.4.22110 and it’s saying updating system software, is it suppose to do anything else more than say that until it’s done. It’s on the main screen.
Thanks
Read then documentation, please.
Since you already reformatted the unit before, it’s recommended that you reformat it again with all the packages. It will be faster and cleaner. From the build you currently have running, it should be a downgrade method. That’s what Syn3Updater should choose depending on your configuration.
You can install just the maps, but will take longer and multiple reboots.
There’s a guide here on the forums for that as well.
Ah didn’t realize that I had to go into the advanced settings on SyncUpdater to get to downgrade. I got it figured out and all set up now. I did see in one video someone saying that you could only do the 2019 maps if you were below a 2020. Is this true?
Thanks
