3.4 dim reverse camera screen
What is your SYNC Region? Africa
What was your Old SYNC Version? 3.0
What is your current SYNC Version? 3.4
What version of Syn3 Updater are you using? 2.10.3.0
Do you have Navigation? No
Have you read the documentation at Syn3 Updater - CyanLabs ? Yes
Do you have a error message, if so what is it? No
[2021/08/05 09:36:37] Selected Region: ROW - Release: Sync 3.4.21194 - Map Version: Non Nav APIM
[2021/08/05 09:36:37] Install Mode: Auto-Detect (autoinstall) Forced: False
[2021/08/05 09:36:37] MY20 Protection: Auto-Detect
[2021/08/05 09:36:37] Formatting USB drive
[2021/08/05 09:36:37] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2021/08/05 09:36:50] Checking Existing File: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:36:50] Downloading: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:37:12] Validating: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:37:12] Downloaded: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:37:12] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:37:12] Downloading: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:42:27] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:42:32] Downloaded: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:42:32] Checking Existing File: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:42:32] Downloading: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:51:33] Validating: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:51:46] Downloaded: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:51:46] Preparing USB drive
[2021/08/05 09:51:46] Checking Existing File: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:51:46] Copying: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:51:55] Validating: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:51:58] Copied: 1U5T-14G658-AG_1626915602000.TAR.GZ
[2021/08/05 09:51:58] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:51:58] Copying: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:53:51] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:54:34] Copied: 5U5T-14G381-ET_1627475308000.TAR.GZ
[2021/08/05 09:54:34] Checking Existing File: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:54:34] Copying: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:57:52] Validating: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:59:05] Copied: 5U5T-14G391-BP_1626959716000.TAR.GZ
[2021/08/05 09:59:05] Generating Autoinstall.lst
[2021/08/05 09:59:05] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Everything else works great. Just the reverse camera screen is very dim. It shows up bright for a split second before and after changing to reverse and is dim after that.
I can’t figure out how to get the brightness back.
If you have not done so, perform a Master Reset of the Sync unit (APIM). In Settings > General > scroll down to Master Reset.
Thanks for the tip F150chief. Did a master reset this morning but no changes. It is usable in daylight because its so bright outside but dusk and darker areas are a problem. Not sure if doing this update has caused it somehow?
bump
Check your lighting settings for the vehicle. Under Sync 3.4, the APIM lighting dimming is now controlled thru the vehicle lighting. If you have auto lighting, try setting that to manual. Also, check the Sync setting for display dimming. You could set it to daytime and test it. I searched the Ranger and F-150 forums and did not find anything about an issue like this.
@mrbeerad how did it go?
Another user with this exact issue, same model, year and region, stated that downgrading to 19101 solved the issue.
