adzz
(adzz)
26 April 2023 19:39
1
Hello
My dumb arse not paying attention selected Non Nav APIM eventhough i do have a NAV when updating from 3.0 to 3.4
Now i have Navigation malfunction (rightfully so) so i did try a master reset but that just kept me on 3.4 with the same fault
Whats the best way to change it a Nav 3.4?
Please dont laugh too much haha
The best way to fix this is to reformat process again, but this time you will be downgrading and then reformatting to add the maps. You will need to re-install everything.
Just use the Syn3 Updater and enter your present version and make sure the region and NAV are correct. The process will be automatic, you do not need to force anything.
adzz
(adzz)
26 April 2023 19:57
3
Okay thanks for the info
Just to make sure
Im selecting the version i just updated to and this time clicked Navigation - Yes
And in the configuration - Select the same version but select the latest map version?
Thanks for your help
Looks fine. It will take like 45 minutes or so for the process to complete in the car…
adzz
(adzz)
26 April 2023 20:00
5
Thanks, just ordering a new USB to arrive tomorrow as im assuming to add nav back on i will need a 32gb one as currently i used a 16 gb one
adzz
(adzz)
27 April 2023 19:10
6
all fixed! thankyou very much
F150Chief
(F150Chief)
Closed
30 April 2023 19:10
7
