After updating Sync 3.4 the compass froze
After updating Sync 3.4.23188 the digital compass froze. Everything works fine. Android Auto works well. Everything is ok, but the compass is frozen to the north. I carried out the service tests and verified that the satellite signal is strong on my Sync 3 APIM. My car is a 2018 Fiesta 1.0 Ecoboost 140CV. Does anyone know what’s going on?
Old SYNC Version: 3.0.20204
Version: 3.0.20204
Install Mode: Deteção Automática (reformat)
My20 Protection Enabled: Deteção Automática
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 EU
FILES (6)
1u5t-14g386-cb.tar.gz (8,5MB)
[05/03/2024 23:08:05] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: APIM sem navegação
[05/03/2024 23:08:05] Install Mode: Deteção Automática (reformat) Forced: False
[05/03/2024 23:08:05] MY20 Protection: Deteção Automática
[05/03/2024 23:08:05] Formatting USB drive
[05/03/2024 23:08:05] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[05/03/2024 23:08:14] Checking Existing File: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:08:14] Downloading: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:08:16] Validating: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:08:16] Downloaded: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:08:16] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:08:16] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:08:17] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:08:17] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:08:17] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:08:17] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:09:27] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:09:32] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:09:32] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:09:32] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:10:03] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:10:05] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:10:05] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:10:05] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:10:22] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:10:22] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:10:22] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:10:22] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:10:59] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:11:03] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:11:03] Preparing USB drive
[05/03/2024 23:11:03] Checking Existing File: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:11:03] Copying: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:11:03] Validating: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:11:03] Copied: 1u5t-14g386-cb.tar.gz
[05/03/2024 23:11:03] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:11:03] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:11:03] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:11:03] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[05/03/2024 23:11:03] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:11:03] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:11:44] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:11:50] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[05/03/2024 23:11:50] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:11:50] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:12:14] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:12:17] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[05/03/2024 23:12:17] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:12:17] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:12:19] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:12:19] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[05/03/2024 23:12:19] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:12:19] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:12:51] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:12:55] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[05/03/2024 23:12:55] Generating reformat.lst
[05/03/2024 23:12:55] Generating autoinstall.lst
[05/03/2024 23:12:55] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Have you done a master reset of the APIM?
Yes
I remember some cars having issues with the compass, but not in the EU.
The solution was installing and older 3.4 release, i’m trying to find which one it’s…
Thanks
Found it: reports started at 3.4.22110.
So, easy way to try is to install a previous build.
If you do not care about RADIO LOGOS, you can install the one just before it, 22048 .
If you want radio logos, try with 21265 .
BTW, 21265 was known to be really stable, so I would suggest going to that build.
I rolled back to version 34.21265 and everything is working. The compass worked normally again. Thank you very much for the support. Great work.
You are welcome, glad it worked.
Take care.
