After upgrade from SYNC 1 to SYNC 3 on Ford Focus 2018 (USA) — DTC errors
Hello, after upgrading from SYNC 1 to SYNC 3 on my Ford Focus 3 Facelift USA 2018, I am getting several DTC errors.
Maybe someone had similar issues?
=== APIM DTC U2101:00-0B ===
Code: U2101 - Control module configuration incompatible
Status (-0B):
DTC present at time of request
Malfunction Indicator Lamp is OFF for this DTC
=== APIM DTC U3000:41-0B ===
Code: U3000 - Control Module
Additional Fault Symptom (41):
General checksum failure
Status (-0B):
=== ACM DTC U2101:00-0A ===
Status (-0A):
Module: Audio Control Module
Below is my configuration:
Interface:
Port: COM3, 115200 bps
Type: Prolific
Adapter: STN2120 v4.1.1 (ELM327 v1.3a)
Min delay: 3 ms (Excellent)
Errors: None
Vehicle:
Model: Ford Focus
Engine: EcoBoost Gasoline Turbocharged Direct Injection
Capacity: 1.0L
Year: 2018 (2017 MY)
Fuel: Gasoline
Transmission: Automatic
SYNC Version: SYNC 3
Main Modules:
PCM: GV6A-12A650-PA / Strategy: HV6A-14C204-GD
APIM: GB5T-14G371-CFC / Strategy: GB5T-14G374-AF
SASM: F1FT-3F818-AC
OCS: F1EB-603B16-AE
ABS: F1FC-2C405-AJ
RCM: G1ET-14B321-AD
PSCM: JV61-3C579-FB
BdyCM: GV6T-14A073-CE
FCIM: F1ET-18K811-HD
HVAC: F1ET-18C612-AJ
ACM: CM5T-19C107-JB
IPC: F1ET-10849-CTP
GPSM: DE8T-19H463-EA
Does anyone know how to fix these configuration incompatibility issues?
Old SYNC Version: 3.4.23188
Status (-0B):
Status (-0B):
Status (-0A):
You have a US car in EU and you changed from 4 inch APIM to a 8 inch Sync 3 Apim?
I think main problem is your car is using asBuilt Configuration of sync 1 on your new sync 3 APIM. You should find a ford focus which originally has sync 3 and copy it’s asBuilt, also do this same for ACM. Just copy it from the same ford focus you use for apim asBuilt
The problem is that I ordered this Sync 3 unit from China (AliExpress) https://aliexpress.ru/item/1005008870785448.html, and I don’t know from which Ford car it was originally taken….(
Odd’s are thats a counterfit APIM. Do you have a picture of the label on it?
No need to find it’s origin car. I saw it’s:
32 GB so it’s from USA and it has navigation.
You just need to find VIN of a Ford Focus from USA with Navigation. Okay I will try to help you, please tell me which country you live in?
Daugavpils, Latvia
Okay, I will try to find APIM asBuilt and ACM asBuilt that matches since your car was originally made for USA
Hie by the way can you please let me know what’s the car’s engine size and trim ?
Engine: 1.0L, Automatic transmission, Sedan, SE trim
Thanks man, I got it, alright you can delete the vin now for safety if you need to
Hie, I sent you a DM with APIM and ACM asBuilt files customised for your new APIM. I hope this will greatly eliminate the DTC errors
