Ambient Colors
Completed a successful upgrade to lastest Sync3 per the tutorial; went without a hitch. Only issue I have come across is with the ambient lighting. All the colors seem to work correctly except the dark blue, it’s purple. It was correct before the update. Heard of this before?
2017 F150 Lariat
Only time I have heard of this is if it is on the Lincoln colors. They are different than the Ford colors.
Master reset then try again. Were any changes made to the Asbuilt info for the BCM or APIM?
I did a master reset after the upgrade. I will try again and see if it helps. No changes to the Asbuilt as far as I know.
Auto Solved due to inactivity
