Hello, I have a 2017 Ford Edge 2.0 SEL, I updated from sync 3.0 to 3.4 but everything was fine until I realized that the maps did not load and that the interior ambient light does not turn on, does anyone have any idea what could have happened? If you can help me I would appreciate it.
Thank you.
One thing I noticed with the last Ford official map update is that it threw the “You may remove USB” message two times when it shouldn’t have. First was after 10 minutes, the APIM restarted then got the message again after 20 minutes, then got it one more time after 30 minutes which all feel into the normal 60 minutes that I saw with NA220 & NA221. I know the maps in the EU are free, so this may or may not matter.
For your ambient light issue, when I did my first 3.4.x reformat from the factory 3.0.x on my 2018 (J series APIM) I had to turn on the headlamps manually, then run a couple of the colours to full bright then full off before they went back to behaving normally.
I don’t know what caused it, but I haven’t had it since through 2nd reformat or my J APIM or the one I currently have installed which is a newer series.
