Afternoon,
I updated my Ford Focus 66 plate UK with Nav to 3.4 19101 ages ago. Have a few issues with Android Auto not always connecting so decided to give it an update.
I’ve used the Syn3 app and it cannot detect if my APIM is MY20 and has told me to come here for advice.
Here is my AsBuilt copy below:
VIN: **************
Version 5U5T-14G381-AP
APIM Model: Unknown
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 12G
24/01/2023 13:12:32 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 676K / 1.1G
/fs/sd/MAP/ = 16M / 2.7G
/fs/sd/MAP/ = 16M / 2.4G
/fs/sd/MAP/ = 9.3M / 1.5G
/fs/sd/MAP/ = 18M / 2.2G
/fs/sd/MAP/ = 24M / 3.7G
/fs/sd/MAP/ = 308K / 38M
/fs/sd/MAP/ = 8.4M / 3.2G
/fs/sd/MAP/ = 29M / 3.6G
/fs/Nuance/ = 26M / 4.4G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 24M / 4.1G
/fs/Nuance/ = 33M / 3.4G
/fs/Nuance/ = 8.5M / 1.9G
/fs/Nuance/grace = 59M / 1.0G
/fs/rwdata/ = 722M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 64M / 1.4G
/fs/mp/resources = 260K / 91M
/fs/images/ = 12G / 54G
Installed Packages
4U5T-14G422-BAE
5U5T-14G391-AK
4U5T-14G423-AA
1U5T-14G658-AD
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
How should I proceed?
Thanks
Chris
SaNdMaN
January 24, 2023, 8:24pm
#3
Did you use Syn3updater for that?.
Also, from which version did you upgrade?.
I’ll upload that XML tomorrow as at work right now.
When I updated it was years ago. I think I used an older cyanlabs app to prepare a USB stick and plugged it in.
Went from 3.3 to 3.4 19101.
SaNdMaN
January 25, 2023, 12:02pm
#6
Do you remember if you reformatted it when doing so?.
Because if you already did, it’s not a MY20 unit.
Yeah, this would be the easiest way to tell
If it helps, I don’t remember this MY20 thing being an issue when I did it.
What was the previous tool that made a USB stick?
Is there a guide anywhere as to how to pull out my APIM and check the date?
UK Ford Focus mk3
I would say it’s not MY20 then, if MY20 wasn’t a thing then you are almost definitely fine, but the liability is with you, were you on before 3.0 previously?
Not on here but i’m sure google can easily show you, basically you pull the trim off around the center console and then some screws, it’s funny cuz i did it so many times when i had my mk3 but now i can’t remember the exact steps.
Thanks, I was on 3.0 or 3.3, can’t really remember.
I know it was a different updater I used to Syn3updater but it was from here. I’m going back a few years though.
Might pull a bit of trim off to be safe.
That pre-dates all the MY20 stuff, again 99% confident you are not MY20 but that 1% is on you
SaNdMaN
January 25, 2023, 2:34pm
#16
Agreed, since you say the vehicle is from 2016 of course is should not have MY20 hardware unless a component was replaced for some reason.
So you should be good, 99%.
All updated, no issues, not MY20. Cheers both.
system
Closed
January 28, 2023, 5:07pm
#18
