Apple CarPlay 2016 Fiesta ST
No “hi” or “thanks”?, ok…
If you performed a master reset and the HUB has been changed, assuming you are using a compatible cable and all conditions are met for it to work, then your issue is that you skipped “an intermediate activation build” by going straight to 3.4.
If this is the case, you are out of luck since you can’t go back to that activation build now.
