to be honest i have no idea what DAB servicelink is, not even sure if i have that setting, i probably do but never noticed.
ok? thats why we have this guide for non 2020 models :)
it's a device like VagCom / VCDS for Volkwagen but for Ford. https://www.ucdsys.ru/?page...
Seems you did something wrong then wrong reformat.lst file for your pack you downloaded maybe
Try providing some useful information, "downloaded the pack from the link" doesn't give me a whole lot to go on, which pack? which country? not really sure wehat your issue is,
11 is correct, 9 map files, 1 logo file, 1 license
Glad to hear it, Thanks :)
Thanks, that makes sense.
i would love to agree with you but you are wrong, in order to update the firmware on the device modules it self you need to flash updated VBF files, only the experimental non public Forscan 2.4 can do this via a USB ELS adapter. UCDS also supports this function and it's considered the best option for flashing VBF files.
Forscan can take ~30 minutes to flash these files.
UCDS does it in seconds.
Additionally setting that ASBuilt without updating the VBF's will either not work at al or work only until SYNC is restarted.
Additionally "No need to buy expensive tools which do nothing more than free ones can." Forscan and ELM or similiar adapters also can not write direct config on BCM which is required to enable Cruise Control on the Diesel Focus Mk3.
