Audio Clipping issue/Rollback
Ever since my update my audio has been cutting out for one second every 30 seconds to 2 minutes. Thinking about rolling the update back all together but cant seem to find a good way to do it. I upgraded from 3.0 to 3.4. Anyone have any thoughts on this??
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.22110
No longer on the USB
You should be on something other than 3.4.22110.
3.4.21265 was rock stable and you can do an in place downgrade using the updater without reformatting, the other option would be an in place upgrade using the updater to the current version 3.4.23188
Have you master reset?
I’ll give the downgrade a shot to 21265 a shot first. hopefully it is same process yea?
yea, that was the first thing i did.
I’m assuming you are referring to usb playback, right?.
Do you have a 2nd USB port? Have you tried it?.
I’m asking these questions because you are the first that I remember saying the skip is that long and that often.
If you want to rule 3.4 out, you should go back to 3.3.19xxx first… If that improves things, then you should move forward…
But the skipping issue is a known 3.4 possible bug…
Well that’s unfortunate. This is through Android Auto, CD, or the Radio. Just out of curiosity is there a way for me to roll back to 3.0 in case i ever need to get a dealer maint done?
In the meantime i will try the downgrade and then see what happens
That’s not normal, I will tell you that.
The USB SKIP/clipping thing yes, but all audio sources “failing” like you are describing?, that’s something else. Try with 3.3 which is the most compatible with 3.0 look, feel and capabilities
As said in multiple places with big red warnings, no, you can’t.
