@F150Chief Thankyou so much! Camera works and I have all my other settings back! The resolution isn’t terrible, the only reason I wanted camera was backing up in tight spaces it helps a ton! And the resolution will not change anything in that regards. I really appreciate everyone’s quick responses and help!
Did you just change the 7D0-08-02 xxxx xxxx *x-- from 0 to 1, or did you load the whole asbuilt?
I loaded the as built you provided then changed the one value
I revised the asbuilt file I attached to include the 7D0-08-02 xxxx xxxx *x-- from 0 to 1 value.
siddiqim90 Sync 3 NEW.txt (493 Bytes)
Glad to help. Enjoy.
