Backup camera not turning on
Hi,
I’ve recently just fitted a Sync 3 APIM into my 2015 Focus ST but I can’t seem to make the backup camera turn on when I put it in reverse.
It is a factory camera, and it worked flawlessly on Sync 2 but now it does not work on 3 even if I did the update to 3.4
I have dug around on Google to try to find an answer but they talk about to enable the option in forscan but clearly it is enabled if you look at the first line (7D0-01-01)
I’ve seen people talk about PDC architecture like CGEA or CIMCA value that I don’t know of
Here’s my As Built data from Forscan:
Help :frowning:
Have you performed the BCM LIN New Module Calibration? In FORScan, that wrench button.
(Not the blue line, above it…)
I’ll try this when I get home thank you!
I just tried, it did not work
Try this from the As-Built Database - CyanLabs
You have a 3, change to 8.
DE00/7D0-01-01: #X##-####-####
0=PDC HMI Disabled, RVC Not Present, Reserved, Illumination FNA
1=PDC HMI Disabled, RVC Not Present, Reserved, Illumination FoE
2=PDC HMI Disabled, RVC Present, Reserved, Illumination FNA
3=PDC HMI Disabled, RVC Present, Reserved, Illumination FoE
8=PDC HMI Enabled, RVC Not Present, Reserved, Illumination FNA
9=PDC HMI Enabled, RVC Not Present, Reserved, Illumination FoE
A=PDC HMI Enabled, RVC Present, Reserved, Illumination FNA
B=PDC HMI Enabled, RVC Present, Reserved, Illumination FoE
You have an 8, change to A.
DE01/7D0-02-02: ####-X###-####
0=DS Off, RSS Not Present, PDC CGEA 1.3, TCU Not Present
1=DS Off, RSS Not Present, PDC CGEA 1.3, TCU Present
2=DS Off, RSS Not Present, PDC CIMCA, TCU Not Present
3=DS Off, RSS Not Present, PDC CIMCA, TCU Present
4=DS Off, RSS Present, PDC CGEA 1.3, TCU Not Present
5=DS Off, RSS Present, PDC CGEA 1.3, TCU Present
6=DS Off, RSS Present, PDC CIMCA, TCU Not Present
7=DS Off, RSS Present, PDC CIMCA, TCU Present
8=DS On, RSS Not Present, PDC CGEA 1.3, TCU Not Present
9=DS On, RSS Not Present, PDC CGEA 1.3, TCU Present
A=DS On, RSS Not Present, PDC CIMCA, TCU Not Present
B=DS On, RSS Not Present, PDC CIMCA, TCU Present
C=DS On, RSS Present, PDC CGEA 1.3, TCU Not Present
D=DS On, RSS Present, PDC CGEA 1.3, TCU Present
E=DS On, RSS Present, PDC CIMCA, TCU Not Present
F=DS On, RSS Present, PDC CIMCA, TCU Present
Since we didn’t receive any feedback from you, this thread will be closed after 2 days since the last response.
