My sync 3 system seemed to be functioning fully before I selected a master reset on the touch screen, the reason why I chose master reset is because it started to act a little bit buggy or laggy, I thought maybe if I did a master reset, I could reconfigure the settings that I like and the system would essentially have a lower amount of cache in the system memory. So after the master reset it appeared everything was working great, but then when it came time for a fresh boot, nothing, just a black screen. Currently in a normal power on engine on cycle, I do get the Ford logo splash screen with some motion, but after that it goes to a black screen and there’s nothing there. Based on how to screen is reacting to touch I believe the touch screen is still reacting and recognizes that I’m touching the screen, the radio is playing in the background, the volume knob does work, but I’m not able to change the radio channel, I haven’t tried pushing any other buttons on the radio itself. Then I thought maybe there was a forscan setting that was corrupting the master reset boot cycle, I read that in some forums or heard that in some YouTube videos too, I thought maybe I could fix this by loading the as builts provided by forscan, I did that last night, I loaded and wrote to the truck the as built provided by forscan, that didn’t help or change anything, it’s behaving the same exact way as it did before that. So I fell back to the cyan labs software, hoping I could get a full boot and go from there. I think no matter what I do I’m just kind of stuck. Using the flash drive that was created by the cyan labs software on the computer, I don’t get the Ford logo splash screen. I’m really not sure what to do now, it seems that if I just take the flash drive which is connected to the USB off the truck, and just start it up normally, I will keep getting the ford flash screen and that will be all. Before trying to correct this with forscan and also before trying the cyan labs software, I tried several times to use the soft reboot function by holding the volume knob and the forward seek button down until I see the Ford logo pop back up, that hasn’t changed a darn thing. I’m really not sure what to do at this point. I am using a 32 GB micro SD card, it is inserted into an SD card adapter, and the SD card adapter is plugged into an adapter to USB-A plug. I created this flash drive with my computer at home with the same configuration. My thought is if the pc and cyan labs has no issue creating this flash drive to load this program, then my truck should accept the software perfectly, the truck doesn’t know any better. Sometimes and very rarely flash drive adapters cause a conflict, but that’s extremely rare with low tech hardware. Frankly a micro USB card plugged into an SD card adapter, plugged into an SD card to USB A adapter, these are all very low tech pieces of hardware. And I’m pretty sure the Ford Sync 3 system along with its USB connecters are also low tech hardware. Back Up camera still works, I do still see a backlight on the screen,
Old SYNC Version: 3
New SYNC Version: 3
No error messages, no messages at all. This flash drive and the software on it don’t seem to be interacting with the sync 3 system and if they are I’m not getting any messages on the screen at all. By the way I’m really not 100% certain what version of sync My head unit had on it before my master reset, I’m not sure exactly, is that something I can find out with forscan?
Syn3 Updater Version: The latest version, just created the flash drive last night
I'm not sure what this means, I would need more explanation or details to be able to provide an answer to this question or request.
