Brightness resets/not adjustable
Just upgraded from version 3.0 build 18025 to sync 3.4.21194 and while i can control the brightness while the car is only on Acc but once started the brightness is locked and the screen is to dark to see. even going in to the screen setting and adjusting the brightness it doesn’t change and then resets to default.
Am i missing something or is there a fix for this?
Please read the FAQ you need to change a asbuilt value.
Thank you, i will give it a try this weekend
