after updating sync 3 to 3.420282 gps navigator does not work, it says navigator failure seems that the maps were not installed, please help
Post your settings, which configuration you had before and what you installed. If maps were not installed, just create a new USB with maps and try again.
If maps were not installed, is because you didn’t include them while making the USB.
como instalo los mapas?
You need to install the maps,
solved, I was not installing the maps of my region, installed the maps of my region and it is solved, thank you very much and good evening.
